Absolute Throttle Position
Discussion in '1st Gen Tundras (2000-2006)' started by TET1, May 9, 2024.
  1. May 9, 2024 at 8:10 AM
    TET1
    TET1 [OP] New Member
    2000 Tundra AC V8 4WD
    Can anyone plug in their OBDII diagnostic tool and tell me what their Absolute Throttle Position is set at? For a V8, 4WD, AC.
    The Haynes manual states that it should be set between 14.4% and 16%. Just wanted to know what others' are set at who are having zero issues.
  2. May 9, 2024 at 8:58 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    14.9% @ 700 RPM.
  3. May 9, 2024 at 9:05 AM
    TET1
    Thank you!
    What about when the truck is off but the ignition is in the ON position?
  4. May 9, 2024 at 9:12 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    18.8%
    TET1[QUOTED][OP] likes this.
  5. May 9, 2024 at 9:19 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    I realize that 18.8% is outside of what the Haynes says, but the truck purrs like a kitten, and as far as I know, it's never been adjusted. It seems like it would make more sense to adjust at idle? Or, perhaps I need to re-adjust mine? Maybe someone with more knowledge on this will chime in.
    Paging Dr. @shifty`
  6. May 9, 2024 at 9:20 AM
    TET1
    Appreciate you checking that!
    I wonder if the Haynes manual is incorrect, cause if yours is at 18.8% and is running fine, why set it between 14.4 and 16 like the manual states.
    I adjusted mine down from 16.1% to 15.2% a few days ago and am now wondering if I should bump it up beyond 16.1%.
  7. May 9, 2024 at 9:24 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Common sense says that a larger % open without the engine running would make sense. Needs more air initially for start. After the engine starts, it drops the % of air entering the intake to avoid a rich condition. If it is initially set at a lower %, after the engine fires it will create a lean condition it an almost 4% reduction holds true. That would explain why it is running poorly. IDK. Just spit-balling here.
  8. May 9, 2024 at 9:39 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    You also have a cable actuated throttle body IIRC. Could be way different for the electronically controlled TB. In fact, I'm not even sure I have adjustment. Yes. Confirmed. This is only applicable for a 2000-2002. The manual states that on 2003 and later models, the TP sensor is NOT removable or adjustable.
  9. May 9, 2024 at 10:06 AM
    TET1
    Ah, that's a good catch. Anybody have a 2000-2002 that would be willing to check?
    Also, I still believe that the 2000-2002 are drive by wire, except they use the Accelerator Pedal Position Sensor and cable to serve as a backup.
