ABS, trailer brake, rear cross traffic, BSM, Tpms, traction control airbag, etc lights all on
Discussion in '2.5 Gen Tundras (2014-2021)' started by DexterL, Nov 12, 2021.
  1. Nov 12, 2021 at 3:44 PM
    DexterL
    DexterL [OP] New Member
    21 lunar rock TRD pro Seqouia
    Howdy folks, have a doosey tonight. I spent a few hours turning my heavily modified tundra back to stock (minus the lift) and went to fire it up and my dash is going bananas. Every dash light is on for the most part, but the truck still drives (and boy is she fast).
    No idea what could have caused this- things I removed- amp powersteps, FRAC harness, hypertech speedometer recalibrator and hardwired radar detector.
    When I was removing my hardwired radar detector I did see a little spark come from the ground wire behind the dash by the fuse panel in the kick panel.
    reading through the forums it looks like folks have had similar issues with abs being the culprit.
    any recommendations? I am on a super tight timeline to figure this out before I take it to the dealership for trade in. Thanks
  2. Nov 12, 2021 at 3:59 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Checked all fuses?
    You didnt touch the suspension so unlikely an ABS wire.
    Have you disconnected the battery for a hard reset?
  3. Nov 12, 2021 at 4:00 PM
    DexterL
    So I just notice my kick panel wasn’t on and one of the plugs that the amp powersteps were wired into was unplugged. Put that back in and voila! The airbag one is still on, going to investigate that further this evening
