Abs traction control light on
Discussion in '2.5 Gen Tundras (2014-2021)' started by dpwill918, Dec 9, 2019.
  1. Dec 9, 2019 at 6:21 PM
    dpwill918
    dpwill918 [OP] New Member
    2014 Red Tundra
    2014 Tundra 4wd limited, lifted. New to me a few weeks ago. Every time the headlights come on the abs and traction control light comes on. Once on every time the truck shifts the accelerator will not function until I let off the gas and reapply. Thinking something with the tail lights but would this cause these symptoms?
  2. Dec 9, 2019 at 6:59 PM
    Check all of your speed sensor cables.
  3. Dec 9, 2019 at 7:02 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Sounds like a short somewhere in the harness.
  4. Dec 9, 2019 at 7:07 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Make sure the brake lights and tail lights are all working correctly, and aren’t aftermarket LED bulbs.
    A poor ground connection to one or both tail lights is another possibility.
    Power feeding back from the tail light circuit to the brake light circuit will cause your exact symptoms.
    14CRWMX likes this.
  5. Dec 10, 2019 at 6:08 AM
    dpwill918
    2014 Red Tundra
    Why would speed sensor send a fault only when the headlights are on?
  6. Dec 10, 2019 at 7:56 AM
    A busted speed sensor can cause crazy things to occur. You do have some weird things going on.
