ABS and Sway Light On
Discussion in '2.5 Gen Tundras (2014-2021)' started by 32TundraCC, Sep 26, 2021.
  1. Sep 26, 2021 at 6:36 PM
    32TundraCC
    32TundraCC [OP] New Member
    I have a '14 Tundra CC and changed out my suspension. The lights came on so I replaced the front L and R sensors and supply wires-since that was found to be common if they strecthed. The lights both come back on and no codes delivered. New battery. Good terminal clamps. But it happened when my ahocks were changed. Fuses all good. Perimeter lights are good. Thoughts? Before I go bat crap crazy. Thanks in advance!
  2. Sep 26, 2021 at 6:41 PM
    2mchfun
    Did you stretch the wires or over extend them when doing your modifications?
  3. Sep 26, 2021 at 7:13 PM
    32TundraCC
    2mchfun, that's what I had assumed. Wasnt my first rodeo with changing suspension, but things can happen. Thats why I replaced the swnsors behind the rotor and also the wire feed to them, on each side. I reset the lights and drove approx 10 miles and they came on again.
  4. Sep 26, 2021 at 7:18 PM
    2mchfun
    You could have a worn wheel bearing causing the sensor and tone ring to not line up correctly. Check all bearings on 4 corners.
  5. Sep 26, 2021 at 7:19 PM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    When you say no codes, you have looked in the ABS module for chassis codes?
  6. Sep 26, 2021 at 7:26 PM
    32TundraCC
    By, "no codes" I meant by the obd2 port. The scanner isnt picking up anything.
  7. Sep 26, 2021 at 7:31 PM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    Right, but do you know if your scanner is only reading the PCM? Just depends on your scanner’s capabilities. If you have ABS light on, there is most likely code(s) in the ABS module.
  8. Sep 26, 2021 at 7:42 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    You may need a zero point calibration... you're probably getting an ABS code, but your OBD2 reader is not able to pick it up... Take it to an Autozone, O'reilly's and see if theyre able to pick it up... C1201 I believe is the code, I posted not long ago about it, and how to go about it, but first confirm your codes.
    32TundraCC[OP] likes this.
