ABS, 4 HI LO, DSC Lights flashing
Discussion in 'Suspension' started by shizzonline, Sep 28, 2018.
  1. Sep 28, 2018 at 7:23 PM
    shizzonline
    shizzonline [OP] Mamba Mentality
    Shahzad K
    Dallas, TX
    2015 Black Tundra Limited
    3.5" Toytec Radflo front, 1.5" rear shackles, 20X10 Cali Off-Road Rawkons, 33x12.5x20 Toyo OC R/T, Apline R Speakers, Alpine swrt Subs, GatorTrax MX Tonneau Cover, Borla Exhaust System, TRD Rear Sway Bar, K&N Air Intake System, Timbren Front Bump stops, TRD Pro Gear Knob, nFaB MRDS Front Bumper, RC 42" LED Curved Lightbar
    Hey Tundra family,
    Need some feedback here. An installer just installed a Toytec Radflo Lift Kit for my 2015 Tundra Limited 4X4 with stock control arm (getting new upper control arm next week) and then when I took it for a drive, the 4x4 Hi Lo lights were flashing and the ABS and DSC lights were on. I got disappointed and annoyed and took the truck back.
    The installer tried tightening some wires and whatever and it still didn't do the job. He says I need to get a new alignment done. I was like ok, I am not taking this truck home until the issue is resolved.
    What could be wrong with my truck?
    @Toytec Lifts and others.
  2. Sep 28, 2018 at 7:36 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Sounds like ABS sensor. Maybe @T-Rex266 can advise.
  3. Sep 28, 2018 at 7:42 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Most likely stretched the abs sensor wire. He’s going to try to blame it on the zero point calibration but all those lights wouldn’t be on.
    NewImprovedRon and Black Wolf like this.
  4. Sep 28, 2018 at 8:24 PM
    ^^^^Yep.....most likely fracked up speed sensor cable.
  5. Sep 28, 2018 at 9:29 PM
    Def stretched the wire
  6. Sep 29, 2018 at 7:23 AM
    shizzonline
    Shahzad K
    Dallas, TX
    Ok that's a starting point thanks guys. If the ABS Sensor wire is stretched, what is the solution how can it be fixed?
  7. Sep 29, 2018 at 7:28 AM
    When it stretches too far the wires in the harness "open" up. They break in two. A replacement speed sensor harness I think is around $100. Maybe more. Very easy to swap out.
  8. Sep 29, 2018 at 7:35 AM
    shizzonline
    Shahzad K
    Dallas, TX
    Thanks Matt. I will give that feedback to the installer. He kept on saying the alignment will fix it.
  9. Sep 29, 2018 at 7:41 AM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    This can sometimes help at least lead you in the right direction.
  10. Sep 29, 2018 at 7:52 AM
    Probably wouldn't hurt to have that chart quick linked here for lack of better words. Maybe the 1st gen chart too. ??
  11. Sep 29, 2018 at 8:55 AM
    viha22
    viha22 MAGA
    WA
    2018 Cement Limited Tundra Crewmax TRD 4x4
    One time i had same lights show up driving my new 2008 from the dealer after purchase.Tightening and giving a few clicks on the gas cap solved it for me.Hope thats what you have and easy fix.
    NewImprovedRon likes this.
  12. Sep 29, 2018 at 9:50 AM
    dud13
    dud13 níl aon tinteán mar do thinteán féin
    2018 MGM 1794 4WD 5.7 (noFFV)
    See Info Page DeChroming... in progress.
    There is a video on YouTube about a guy installing his own Bilstein’s up front. I’ll find it later tonight. But it details the process and that specific wire how you have to take care not to pull on it. Most likely the thing this guy says take care not to do, your installer did.
  13. Sep 29, 2018 at 5:04 PM
    shizzonline
    Shahzad K
    Dallas, TX
    Dud13 if you can please share that video that will be great.
    So the alignment didn't do anything and the installer has ordered the ABS Line for the passenger side from Toyota. The part # is 90947-A2090. Is that the part wire you are talking about?
    Will get that delivered on Tuesday and I'll see if that resolves the problem.
  14. Oct 1, 2018 at 10:45 PM
    KevinK
    Tundras to Sedona
    I saved it to a photo album on my phone along with stuff like my health insurance card and torque specs. That way I always have it and other important shit in my pocket without taking up precious cargo shorts room.
    Black Wolf[QUOTED] and 831Tun like this.
  15. Oct 1, 2018 at 10:48 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    So,,,,, you're saying the answer is in your shorts?
  16. Oct 2, 2018 at 12:06 PM
    KevinK
    Tundras to Sedona
    831Tun[QUOTED] likes this.
