AAL to offset constant load of 200 lbs
Discussion in 'Suspension' started by Oper8r, Feb 26, 2016.
  1. Feb 26, 2016 at 8:20 AM
    Oper8r
    Oper8r [OP] New Member
    Stuttgart
    Sold my 2016 TRD PRO - Currently in BMW 535d Wagon
  2. Feb 26, 2016 at 11:41 AM
    TruckLife900
    TruckLife900 I'd rather B hunting
    2013 White SR5
    Cool looking system!
  3. Feb 27, 2016 at 3:19 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I have aal on my truck and it definitely squats a lot less with similar weight. Go for it. My concern when I was getting them was with the ride. So many people say that the ride is harsh with aal. I think the ride is pretty good. With extra weight in the bed, it should be even better.
    Black Wolf and Oper8r[OP] like this.
  4. Feb 27, 2016 at 5:56 AM
    Oper8r
    Stuttgart
    ^Thanks, this helps.
  5. Mar 4, 2016 at 3:34 PM
    Oper8r
    Stuttgart
    I ordered the Decked storage unit, but now I'm trying to figure out whuch aal to go with. Anyone ever tried these from Wheelers?
  6. Mar 4, 2016 at 3:41 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    No experience with the Icon AAL. Searched and found it to see what the description was. http://toyteclifts.3dcartstores.com/ICON-15-inch-Progressive-AAL_p_1203.html
    "replaces all the factory secondary leafs while retaining the factory main and overload springs. This allows us to modify the spring rate to increase ride comfort, obtain lift height, maintain load and towing capacities, and increase wheel travel."
    Sounds like a good add on for a nice ride but not sure with added weight.
    zcarpenter92 likes this.
  7. Mar 4, 2016 at 3:42 PM
    csuviper
    Broomfield, CO
    Wheelers sounds about the same "Maintains standard load and towing capacities."
  8. Mar 4, 2016 at 3:43 PM
    csuviper
    Broomfield, CO
  9. Mar 4, 2016 at 4:12 PM
    Oper8r
    Stuttgart
    Do you think these two products might be better because they are multiple leafs possibly made better and not just one or two that would be used as shims?
  10. Mar 4, 2016 at 7:47 PM
    csuviper
    Broomfield, CO
    You end up removing most your stock leafs and replace with the icon or wheelers one. Would be a good ride I'm sure but it's set up for stock not the added weight.
  11. Mar 4, 2016 at 7:51 PM
    csuviper
    Broomfield, CO
    You could get a new custom leaf pack from Alcan set up for the lift and added weight or the OME pack with lift. Those would be better as they lift with the added arch which would help with the added weight.
  12. Mar 5, 2016 at 5:19 AM
    Oper8r
    Stuttgart
    Would this cost me an arm and a leg over the icon and wheeler options?
  13. Mar 5, 2016 at 9:42 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I had this on my taco for years and have had it on my Tundra for a few months with no issues. The "harsher" ride isn't enough for me to really notice but the ride is definitely better when hauling or towing. I got a little over an inch in the rear and I'm a CM.
  14. Mar 5, 2016 at 10:37 AM
    csuviper
    Broomfield, CO
  15. Jul 4, 2017 at 3:38 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I wanted to revive this thread....
    I want no lift in the rear but I do want a smoother more Progressive spring rate.
    Talked with both icon and wheelers, they both mentioned that the mini enhancement pack can be added while keeping the overload Leaf uninstalled to net me about an inch of lift.
    Anyone on here running the Deaver Mini pack or the wheelers enhancement pack or the icon Mini pack and the overload Leaf removed?
  16. Jul 4, 2017 at 5:31 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I'm running the Icon pack with 2"CB shackles, silky smooth pro ride is still there. I'm carrying around 1K extra constant payload. Ride height is slightly higher than stock. I also added shims up front.
    Law323 and 14burrito like this.
  17. Jul 4, 2017 at 5:36 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    I only maybe 5000 lb couple weekends a month and that's a trailer so that actual tongue weight or bed weight is much less. And when we go camping or shooting I usually have a few hundred lb in the bed.
    So I really don't want any lift, i like the truck stance right now I just want something with a little bit better ride
    ... to add I also don't want to be spending six seven $800 on a leaf pack so I'm trying to figure out something that'll be a good fit for the interim.
  18. Jul 4, 2017 at 5:50 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Modified leaf spring geometry is the best solution for permanent load conditions. If you're compensating for occasional or intermittent loading you will be happiest with a system that is applied specifically when needed, like air bags.
    Rex Kramer and Black Wolf like this.
  19. Jul 4, 2017 at 5:55 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    .... that's the thing though, I don't want to compensate for the intermittent loading lol
    Oh well, after talking to a few people, icon and wheelers I think I'm just going to do the expansion pack without the overload leaf and call it a day.
  20. Feb 25, 2019 at 8:03 AM
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    Did you end up with the wheelers enhancement pack and how has it worked out / held up?
  21. Feb 25, 2019 at 11:51 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    I ended up going Icon expansion pack. 1st set clapped out pretty quickly, IIRC less than 6 months.
    With that said, Icon specifically told me I can run without the overload and that it will ride great....well run ahead to when I reached out to Icon because the pack was crapped out. They asked for pics and such, no issues - sent. They then come back and say no no no, you cannot install without the overload and they would not warranty the pack. I said, well well well, sent them screenshots of my conversation (glad I don't erase things)....later that day tracking for the new expansion pack.
    Aside from that, I have been happy with the lift and ride quality. I am running them with ADS with clickers out back so have a little better control with dry vs loaded. I have overcome the 1" vs 1.5" and the 1.5 ended up being just fine because my front lift is limited to a min of 3" - looks great. Prior to, I was sitting about 2.5 and liked the 1" look better. I am also running the Wheelers superbumps out back (fronts as well).
    All in all, all worked out.
    TacoWuzzaTurd[QUOTED] likes this.
  22. Jan 29, 2020 at 11:53 PM
    Pomp_Cat115
    Pomp_Cat115 New Member
    Los Angeles, CA
    How has the icon expansion pack held up?
  23. Jan 30, 2020 at 5:25 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    After knowing there is in fact a proper way to install (with the overload in place) no issues. after some towing, loads in the bed with an average of 150/200lbs dead weight back there every day - lift height still as expected.
    I'm actually shocked the isolator pads are all still in place. They help keep the pack quiet.
    Pomp_Cat115[QUOTED] likes this.
