A tad rough, but tolerable
Discussion in 'Suspension' started by JROCK915, Dec 21, 2015.
  1. Dec 21, 2015 at 11:13 AM
    JROCK915
    JROCK915 [OP] Trust noone, and be prepared!
    Jeremy
    Palm Desert, CA.
    2011 Trail ready SR5
    Icon 1.5" leaf pack, w/ Pro Comp 1" block Rear Pro Comp SS shocks ToyTec/Eibach coil overs, on Pro Comp SS shocks, SPC UCA AFE Stage II C.A.I, and throttle body spacer N-Fab nerf bars N-Fab RSP front bumper with Hella Optilux 30" LED bar, and Hella Optilux 4" (2) HID driving lights Federal Couragia 33x12.5x20, wrapped around 20x9 Fuel Boost Fender flares Spyder LED tail lights (smoked out)
    @Sean266 ,
    Is there a way to "soften" up the P.C/Toytec coilover setup? I went w/ the silvers, because I despise the color red (on my truck). Even knowing the reds were "softer".
    I don't mind the roughness as much, but the wifey would like it a bit softer.
    They're set @ roughly 2". Due to having the MaxTrac Spindle too.
    Thanks for any help/advice.
  2. Dec 21, 2015 at 11:48 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Get the red and paint them to any color you want.
    As you could see in my signature, I like the red. But OME shocks and struts came in yellow. I sanded them and painted them red.
  3. Dec 21, 2015 at 11:54 AM
    JROCK915
    Jeremy
    Palm Desert, CA.
    If I go that far, I'm switching the whole setup, to these (just the fronts). But $$$ matters. I've got other projects on her, that take precedence.
    OcotilloSR5 likes this.
  4. Dec 21, 2015 at 1:47 PM
    Per Toytec
    The red and the silver coils are both exactly the same spring rate so they should ride the identical
  5. Dec 21, 2015 at 1:52 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    So you would consider going to a procomp shock from a toyotech? I thought these toyotech lifts were good?
  6. Dec 21, 2015 at 1:57 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    OH! I was under the assumption the reds were less. I'll see if I can find that. I trust your word though. Thanks.
  7. Dec 21, 2015 at 1:59 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    These are from Toytec. They're P.C/ Toytec combo.They rock. They're just a bit stiff.
  8. Dec 21, 2015 at 2:03 PM
    Yessir. Straight from the CEO of Toytec himself.
    JROCK915[QUOTED][OP] likes this.
  9. Dec 21, 2015 at 2:14 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    You're the man, thanks.
  10. Dec 21, 2015 at 2:59 PM
    Bl@ckBea$t
    Bl@ckBea$t New Member
    12 Blk Dbl cab
    Dual 12x6 BaMuffler's, Rear-cat Delete, TRD Sway Bar
    You could try getting them re-valved to a softer setting. It's cheaper than buying a whole new setup. What are the spring rates on these, 600 or 700?
  11. Dec 22, 2015 at 3:16 PM
    N8Dizzle
    N8Dizzle New Member
    Nate
    Seattle
    2016 Magnetic Gray Tundra Platinum
    Toytec Boss Lift w/AAL, TC UCA's, Fuel Trophy D552, 305/70R18,Cooper STT Pro Tires,Interior/Cargo LED's, 10% Window Tint, Hypertech Speedo Calibrator, anytime fogs, WeatherTech Digital Fit Mats
    They have a 650 and 700 in red.
  12. Dec 30, 2015 at 8:20 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Thanks. I'll check w/ my offroad guy. Shes getting new stoppers next week anyways. They should be 700.
  13. Dec 30, 2015 at 8:23 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Off subject for this but....
    I'm getting all new brakes next week. My rig is @ 5". My guy says I need some brake line extensions. Would those line extensions you guys carry, be enough, for that height? I dont ever plan on going higher. tia.
  14. Dec 31, 2015 at 9:48 AM
    ABS extension you mean? Yessir they do. I'm not with Toytec, btw.
  15. Dec 31, 2015 at 10:03 AM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Thanks.
    Oh, sorry. Some how I assumed you were. I'll stop harassing you w/ Toytec questions, lol.
  16. Dec 31, 2015 at 10:06 AM
    Virgils12
    It's fine I think he is a honorary spokesman for them! :cheers:
  17. Dec 31, 2015 at 10:07 AM
    Ya I don't mind. Feel free to ask away and I'll get an answer for u. :thumbsup:
    JROCK915[OP] likes this.
  18. Jan 9, 2016 at 1:33 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Hey guys,
    I just noticed this today! Wondering if this could be a cause of why my setup feels rough, OR was it just over greased when installed?????
    Just in case you can't tell....
    The driver's side is shadowed w/ greasy film (only on the foward side).
    The passenger's side is spotless.
    What's your opinions?
  19. Jan 9, 2016 at 3:40 PM
    Bl@ckBea$t
    12 Blk Dbl cab
    Go get yourself a no loss pressure gauge and see what your nitrogen levels are at brother. If you don't wanna do that you can go to a off-road shop that can check your pressures. It looks like you're leaking oil.
  20. Jan 9, 2016 at 4:31 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I agree looks like an oil leak. How old are they?
  21. Jan 9, 2016 at 6:46 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Maybe 9-10 months. How would I hook up one of those pressure gauges to check the pressure in it?
  22. Jan 9, 2016 at 9:52 PM
    csuviper
    Broomfield, CO
    Might call up Toytec and ask them about what you can do.
  23. Jan 9, 2016 at 9:55 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Yea.... that was my first thought. May just swap them for a set of rebuildables anyways. Icons or the Pro Comp Black series. Thanks.
  24. Jan 9, 2016 at 9:59 PM
    csuviper
    Broomfield, CO
    Im sure they can be rebuilt.
  25. Jan 10, 2016 at 7:27 AM
    Is the spindle after market? When you begin mixing different parts together that can cause for a crap ride. Majority of the reports they receive on their suspension are solid...that being said, PC is sort of on the lower end as far as quality goes IMO.
  26. Jan 11, 2016 at 10:19 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Those coilovers are not user serviceable/rebuildable
    There is no port. And even with coilovers that have a schrader, every time you check the pressure you lose 10-15 psi.
    OP...the problem IMO is a 700 lb spring (and yes you have a 700...the code on the side of the spring says it's a 16" long spring, 3" ID, and 700#). That's too much for this truck unless you have a plate bumper and a winch. And the fact you don't have a front diff. I rock a 600 lb spring and my own valving and my truck rides like a damn caddy.
    PLC721 likes this.
  27. Jan 18, 2016 at 4:44 PM
    Bl@ckBea$t
    12 Blk Dbl cab
    I have a "no loss" pressure checker. Doesn't lose any nitrogen pressure when checked, hence no loss lol. I'd go with the 600lb Spring tho, I have 700's and 20/10 valving on my kings, very stiff.
  28. Jan 19, 2016 at 12:18 PM
    jberry813
    Lake Tahoe
    NAL is AFTER the shock is charged, not just checking the pressure. I have a NAL chuck on my nitrogen setup as well and intimately familiar with them. Just by putting on the NAL and closed valve, you still have to pressurize the gauge and whatever cavity you have in between the valve and NAL chuck. You can't do that without losing some nitrogen pressure, especially considering how small the nitrogen cavity is. It's not like checking the pressure a tire.
