A/T moves slowly even at high rpm
Discussion in '1st Gen Tundras (2000-2006)' started by Asherc9704, Apr 18, 2022.
  1. Apr 18, 2022 at 3:00 AM
    Asherc9704
    Asherc9704 [OP] New Member
    Asher carney
    2002 tundra sr5
    Hi I recently was driving my tundra (4.7l 4x4 auto) when I noticed the rpms would fly up when I hit the gas while driving. They would go back to normal after a few seconds like it was going in and out of gear. A few minutes later I cam to a stop light and when the light turned green I couldn't go into gear at all. I pushed it into a parking lot to see what was going on and I noticed that if you rev it in gear it would move just very slowly even at 3 to 4k rpm.
    Here is a link to a video of the driveshaft movement compared to the revs. (There is no drivshaft to the rear as I am waiting for parts to rebuild the rear differential)
    https://photos.app.goo.gl/fF9DxrJR4FWtiwr3A
    Any information as to what might be wrong will be appreciated, thank you.
  2. Apr 18, 2022 at 3:42 AM
    NetGnome
    NetGnome New Member
    NJ
    2003 RC V8 4wd, 2007 Sequoia V8 4wd
    Removed lots of rust.
    Check fluid level
  3. Apr 18, 2022 at 3:56 AM
    Asherc9704
    Asher carney
    2002 tundra sr5
    Fluid level is normal
  4. Apr 18, 2022 at 4:00 AM
    Definitely a problem in the transmission here. Bad pump? Bad torque converter? Low fluid would be the most common problem, but you say it’s normal. What color is the fluid? What codes are being thrown?
    Sirfive likes this.
  5. Apr 18, 2022 at 7:37 AM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Could be the converter, trans pump, check-balls getting stuck. I think dropping the trans is in your future.
  6. Apr 18, 2022 at 9:13 AM
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    Do I have this right that you were driving with the rear shaft disconnected? So in 4hi and using fwd? I think the transmission needed that resistance... Ive been wrong before tho
  7. Apr 18, 2022 at 11:05 AM
    Just seeing that bit of info. How long have you been using the truck in 4x4 with no rear drive shaft?
  8. Apr 18, 2022 at 11:25 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    That’s exactly what I was thinking. Usually that’s only done for diagnostic purposes. @empty_lord just recently did that himself troubleshooting some issue I believe.
  9. Apr 18, 2022 at 11:27 AM
    Right? Blow a U-joint, limp it back home or to a safe location. Wouldn’t keep daily’ing it for sure.
  10. Apr 18, 2022 at 11:33 AM
    tundratoofun
    Glendale
    Beast
    Ive done for a few miles to get back to the trailer, it was brutal
    Jack McCarthy likes this.
  11. Apr 18, 2022 at 11:38 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    You can without hurting anything
    Assuming your not beating on it
  12. Apr 18, 2022 at 3:45 PM
    Asherc9704
    Asher carney
    2002 tundra sr5
    I've been driving it in fwd since November and its driven perfect since then. It doesn't seem like that's the issue. Probably something electrical or the tc. Im planning on dropping the trans this week to diagnose it
  13. Apr 18, 2022 at 3:50 PM
    skip1980
    skip1980 New Member
    Columbia, Missouri
    What you are describing sounds exactly like a slipping trans. Probably going to have to pull transmission. Does it work in reverse?
  14. Apr 18, 2022 at 3:58 PM
    :eek:
  15. Apr 18, 2022 at 4:18 PM
    Could it be a transfer case issue?
    FrenchToasty likes this.
  16. Apr 18, 2022 at 4:32 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    T-case chains make a helluva racket when they stretch enough to start jumping teeth. Hasnt happened to me, but i’ve heard it on other trucks.
    tundratoofun likes this.
  17. Apr 19, 2022 at 11:56 AM
    Beefnbread
    Beefnbread Electric Soup
    Oregon
    2000 SR5 Tundra 4x4
    Yeah I think trans is probably fine. You usually know it’s your trans when you get funny sounds and some smoke before it leaves you stranded. My vote is on the transfer case from driving consistently in 4 wheel.
  18. Apr 19, 2022 at 12:05 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    unless the rear output still spins in 2wd. The planetary for 4lo or a stretched chain would make racket, a broken chain wouldnt have moved the truck a couple inches like i think it did.
    fluid isnt flowing right. I’d guess pump, but it could be anything from the shift lever to the check balls. Need more info. But i like the sound of the glasspack.
    maybe worn the splines off a shaft, or the shift fork, but transfer cases are really simple, and theres not alot to go wrong.
    Jack McCarthy and Beefnbread like this.
  19. Apr 19, 2022 at 12:13 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    Maybe t-case is low on fluid or hasn’t had maintenance. When they go bad, they like to jump in and out of 4 wheel.
    If the transmission isn’t flowing properly, you’d get some metal shavings from friction wouldn’t you? Maybe check the pan and see if you have a lot of buildup on the magnet.
  20. Apr 19, 2022 at 12:36 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    In Op’s video, the rear shaft is spinning, and I’m assuming it’s in 2wd since the vehicles isn’t moving. Unless it’s on a lift or something .
  21. Apr 19, 2022 at 12:50 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    It doesnt look like its spinning. Full rotation? Rocks it a little, but diff is still holding.
    either the fluid isnt engaging, or trans is slipping hard. G’naded t-case would more likely lock up hard. Fluid couplings allow rock & roll.
  22. Apr 19, 2022 at 1:02 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    I turned off the video after I saw it spin a little bit just to verify, but yeah, it wouldn’t get the diff moving at all.
    Yes t-case would have hard lock up
  23. Apr 19, 2022 at 1:07 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Engine doesnt sound loaded enough.
    kinda sounds barely more loaded than neutral. Pump, converter, or balls. 2 of those can be checked by pulling the cooler line. Or, it could be glazed, bald bands and clutches.
  24. Apr 19, 2022 at 1:21 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    You’d probably get codes for burnt out clutches? I’ve always got codes for it on other vehicles that were smoked out. Also worn down clutches (in my experience) have always been able function in a half ass manner. Also usually worsens over time and doesn’t happen randomly at a stop light. You’ll usually see it coming you know :D
    Sirfive[QUOTED] likes this.
  25. Apr 19, 2022 at 1:40 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    You’re right, but grandmas old e-series 30ft motorhome had huge chunks floating in the fluid. No clue how it kept driving. Put the slurry back in, and it kept running flawlessly for 10 years. Transmissions are mechanical magic. Sentient, only fail when they want to.
  26. Apr 19, 2022 at 1:48 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    Big chunks for a big transmission haha!
    I think those transmissions are like 6 feet long and as wide as a redwood tree
    Also allison transmission? They make a lot of them for motorhomes.
  27. Apr 19, 2022 at 1:56 PM
    Jack McCarthy
    Bill
    North of Boston
    So it sounds like our part-time 4wd T-cases are just that…part-time. Or can they be driven daily in 4wd every day as long as the road is acceptable for it?
    I kind of wonder if putting the fully loaded weight of the truck on the front drivetrain is okay for just the front wheel drive portion of 4wd since it wasn’t designed to be used that way.
  28. Apr 19, 2022 at 2:16 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Awd t cases have clutch packs. 4wd is solid. Like gmc syclones had awd tcases from astrovans and olds bravadas and 4x4 s10s and blazers were solid.
  29. Apr 19, 2022 at 3:14 PM
    tundratoofun
    Glendale
    Beast
    I a s10 blazer, my buds was almost as tough as my ranger. Sorry off track again.
    Thats what im thinking now also. No center diff and all that either
  30. Apr 19, 2022 at 3:42 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    Also off track but I cracked my old transfer case on my 89 s10 going over big rocks in mountain roads
    Since we’re talking about s10 transfer cases
