A question for you math wizards and engineers
Discussion in 'Performance and Tuning' started by gosolo, Oct 23, 2016.
  1. Oct 23, 2016 at 2:06 PM
    gosolo
    gosolo [OP] You Don’t Know Who I Am But I Know Where You Live
    Ray (or maybe Dale)
    NW Oregon
    Isn't there a simple equation to determine power loss when upsizing tires?
    Initial HP is fixed but probably unknown.
    Height dictates circumference and distance traveled per revolution.
    Increasing diameter decreases torque by ? %.
    Wondering if someone with better math skills than mine can 'splain why this can't be a simple equation.
  2. Oct 23, 2016 at 3:19 PM
  3. Oct 23, 2016 at 6:04 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Hey gosolo, I am pretty good at math and the best answer I have for you is : Re-Gear. My formula for your equation : Bigger than stock tires = lower gears. You more than likely have 4:30 and the only gear swap for our trucks at this time is 4:88. I am running a 34.75" tall tire and put 4:88's in right after the tires. BEST decision of my life. Truck performs beyond expectations. Check with Kieth at Dirty Deeds and he will be the first to tell you, re-gear is the best route after tire increase. Best of luck to you.......Enjoy
    dirtydeeds likes this.
  4. Oct 23, 2016 at 8:35 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I have regeared trucks in the past and may do so again but for now it is not necessary. I'm actually trying to find out if there is a simple equation to determine the % of power lost by increasing tire diameter a known amount.
  5. Oct 23, 2016 at 8:46 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm guessing that there isn't a simple formula. There are just too many variables. Each brand of tire is going to weigh different, aftermarket wheel weight, things like that. The fuel you're running, elevation, etc. That's probably where the dynometer came from, a measurement directly at the wheel.
  6. Oct 23, 2016 at 8:53 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You would definitely have to factor in weight not just diameter
  7. Oct 23, 2016 at 8:56 PM
    mudsweatngearz
    mudsweatngearz New Member
    Grant
    Arizona
    2016 Limited TRD CM 2016, Tacoma TRD Sport, 2005 Tacoma TRD Sport
    Window tint
    My theory:
    No power loss. The engine will still produce the same amount of power no matter what size tire you use. No torque loss either. Where in the torque curve power is produced may change depending on tire diameter.
    Bear likes this.
  8. Oct 23, 2016 at 8:57 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Most of the other potential variables go away if you're staying with the same vehicle. I suppose an average weight increase could be determined?
  9. Oct 23, 2016 at 8:58 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Sure the engine produces the same power but it isn't delivered at the asphalt.
    15whtrd and ColoradoTJ like this.
  10. Oct 23, 2016 at 9:02 PM
    mudsweatngearz
    Grant
    Arizona
    Window tint
    Why not? Same amount of power reaches the rear axle no matter what.
  11. Oct 23, 2016 at 9:02 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Bigger wheels and heavier tires means larger moment of inertia which mean they take more torque to turn. Think of it like trying to spin a steel rod on it's axis versus trying to spin it like a propeller.
    Also, if the truck is lifted the aerodynamics change, more area is exposed to wind resistance.
    You could do some quick and dirty calculations knowing the diameter and weight difference and get a percentage difference.
    To do more detailed calculations you'd need exact weights and dimensions.
  12. Oct 23, 2016 at 9:19 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    This is the assumption that gets everyone into trouble. You're not taking into account the biggest variable.
    The tires are constant. But our trucks aren't carbureted, or the engine would be a constant. Since we have an ecu that is looking for 'load', you have to account for every degree of timing the ecu pulls and every point of afr the ecu adds.
    Figure 10-15hp lost for every degree of timing pulled.
    The ecu is constantly cross referencing throttle position, to mass air volume, to... you guessed it, wheel speed.
    By slowing the wheel speed in relation to the other 2 inputs you're making the ecu see a false level of load. With artificially high load the ecu pulls timing and adds fuel in an attempt to keep our 10.2/1 compression ratio motor from blowing since it assumes we are only running 87 octane.
    I have seen 40 hp missing for a truck running 35's, and when we installed stock tires and drove the truck around the block and put it back in the dyno, it magically had an extra 40hp.
    While gearing doesn't directly add 40hp, it does fool the ecu into not pulling 40 hp;)
    Im sure Toyota engineer Mike Sweers knows better than me, but this is what I've seen in the last 13 years of 'hot rodding' Toyota Tundra's:)
    louscrw, ColoradoTJ and 831Tun like this.
  13. Oct 23, 2016 at 11:23 PM
    mudsweatngearz
    Grant
    Arizona
    Window tint
  14. Oct 23, 2016 at 11:37 PM
    dirtydeeds
    Keith
    USA
    Newton had no idea engines would be tuned with electronics. Haha.
    ColoradoTJ likes this.
  15. Oct 23, 2016 at 11:54 PM
    mudsweatngearz
    Grant
    Arizona
    Window tint
    Still does not change laws of nature....even Toyota can not beat the fundamental laws of nature..hahahaha
  16. Oct 24, 2016 at 12:16 AM
    Here you go, and this backs up what Keith was saying.
    http://www.4x4abc.com/4WD101/math_wheels.html
  17. Oct 24, 2016 at 3:37 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    If goimg with bigger tires on a 4wd do you have to change front and rear gears?
  18. Oct 24, 2016 at 7:46 AM
    Good question.
    Yes, you have to change both front and rear gear sets. Since you most likely have 4.30 gears, what do you think would happen if you installed 4.88 gears in the rear axle only and then placed the truck in 4wd at 10 mph? The front axle would be going faster than the rear right? The transfer case would not last long at all.
    Hope this answers your question.
  19. Oct 24, 2016 at 10:40 AM
    MK44
    MK44 New Member
    2010 Tundra 4x4, 2002 Tundra 4x?
    Torque at shaft remains the same. Let's say 100 ft.lbs and your radius is 1 ft (2ft dia tire) so the force applies is 100 lbf. Go with a radius of 2 (4 ft dia tire) the force to the road is now 50 lbf. Let's say friction is 75 lbf basically you do a burn out with little tire and nothing with big tire. By changing the gearing you adjust torque at axle thus equalizing the force for the tire. Again this assumes a lot of constants which doesn't exactly translate to the real world but the principal is correct increase diameter decrease force to road (this does not mean it will adjust horsepower as that is a different unit)
    Bear, mudsweatngearz and dirtydeeds like this.
  20. Oct 24, 2016 at 2:38 PM
    MK44
    MK44 New Member
    To supplement the comment horsepower is ft-lb per second or torque divided by time... since the torque is fixed and tire diameter does not effect time... no change in horsepower. Just a change in force applied to pavement.
    mudsweatngearz and gosolo[OP] like this.
  21. Oct 24, 2016 at 2:42 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    A lot like what I said above in post 9, but my language lacks your sophistication!
  22. Oct 24, 2016 at 2:52 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Wow, I missed this aspect entirely. I was focusing only on the loss of mechanical advantage with larger tire diameter. The power loss at the wheel to road interface predates all of the electrical controls you describe. I really appreciate the resources available here on this forum!
    dirtydeeds[QUOTED] likes this.
  23. Oct 24, 2016 at 4:41 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Oooo! I just remembered another variable to consider with bigger tires......spring wrap....muhahaha!
    gosolo[OP] likes this.
  24. Oct 24, 2016 at 7:40 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yeah right. And don't forget the alignment of the planets and the occasional solar flare
  25. Oct 24, 2016 at 7:46 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    am sipping scotch now so I better quit posting. I have a tendency to get sarcastic and occasionally belligerent.
  26. Oct 24, 2016 at 7:53 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Dark matter man, dark matter.☄
    gosolo[QUOTED][OP] likes this.
