A p0420 ugh
Discussion in '2nd Gen Tundras (2007-2013)' started by PNWtundrite, Feb 20, 2024.
  1. Feb 20, 2024 at 4:36 PM
    PNWtundrite
    PNWtundrite [OP] New Member
    2010 Tundra TRD rock warrior black
    Demello front number with winch and lights, Bilstein 5100 Eibach spring 3" front lift and 5100 rear 2" lift, Android auto stereo with front camera
    Overheated my engine on a cold snap day. Found my thermostat was broken replaced it. And the process I broke one of the plastic vacuum tubes that goes to the air pumps and runs underneath the air intake manifold. I took off the air intake manifold and replaced the vacuum tubes.
    Now I have a p420 any thoughts
  2. Feb 21, 2024 at 6:04 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    Catalytic Converter failing or O2 sensor
  3. Feb 21, 2024 at 6:20 PM
    PNWtundrite
    Someone just needs to steal my catalytic converter then those things get replaced :)
    Tridom likes this.
  4. Feb 24, 2024 at 7:00 AM
    Orions Dad
    2007 Tundra 4.7L
    Exhaust leaks can also cause a P0420 code
    https://youtu.be/ww0ottmbzes?si=AzulA4_4brb1YjzZ
    if you do have a bad catalytic converter there are products which can help clean them such as Cataclean, Scotty Kilmer has a few videos where he uses lacquer thinner
  5. Feb 24, 2024 at 10:46 AM
    Orions Dad
    2007 Tundra 4.7L
