War Machine’s Build Thread
Discussion in '2.5 Gen Builds (2014-2021)' started by War Machine, Sep 14, 2017.
  1. Sep 15, 2017 at 5:17 AM
    War Machine
    War Machine [OP] SSEM # 5 3MW
    Found a guy local who quoted me $300.00 to powder coat the bumpers. Does that sound reasonable? The only issue there is having to remove them myself. That looks like a pain in the ass. He said it would take a week.
  2. Sep 15, 2017 at 5:36 AM
    Borgs
    Borgs New Member
    PA
    That's really high. I paid $70 for the front, and my guy is a pro that does fabulous high-end work (choppers, other bikes, hot rods, and other industrial coatings) and came highly recommended.
  3. Sep 15, 2017 at 5:39 AM
    War Machine
    Ok. Thanks for the input. I had no idea what a competitive price range was for this.
  4. Sep 15, 2017 at 6:11 PM
    War Machine
    1505524143011.jpg Added tail lights.
  5. Sep 15, 2017 at 6:55 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    What are those ??...I like em :D
  6. Sep 15, 2017 at 7:06 PM
    War Machine
    Darth Tundra[QUOTED] likes this.
  7. Feb 19, 2018 at 12:07 PM
    War Machine
    Got the bumpers powder coated finally. They turned out pretty much perfect. I only put the front ones on. I couldn’t get the damned rear ones off for the life of me. I’m going to try and find somebody to help with them.
    E36F6634-C59B-4D46-9CDA-291E15A23895.jpg BDA85032-57E5-42DA-B8B9-0DB0E2DD9149.jpg
    Pudge, blue16, mlucas555 and 4 others like this.
  8. Feb 19, 2018 at 12:10 PM
    Shaggypeach
    Shaggypeach New Member
    How do you like the spiders?
  9. Feb 19, 2018 at 12:19 PM
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    That looks clean,might be the way for me to go if i can get them to match the silver sky metallic finish
  10. Feb 19, 2018 at 12:25 PM
    War Machine
    I like them a lot. Almost wish I’d gotten the smoked ones though.
    Pudge likes this.
  11. Feb 19, 2018 at 12:25 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    HELLS YA !!!!!... AND BLACK REPRESNTING ...YO !!!!!....LOOKS ...WELL.....ITS BLACK .....WHICH MEANS .......BADASS !!!!!
  12. Feb 19, 2018 at 12:26 PM
    War Machine
    I do wonder about that. Black is probably the easiest to match. Somebody here had some done to match MGM, and it wasn’t close at all.
  13. Feb 19, 2018 at 12:27 PM
    Shaggypeach
    I am seriously considering this one with 6k hid
    https://www.protuninglab.com/hidxe20totul.html
    I've had Osram's on my prev vehicle and they were amazing. My concern is that in the description it says level adjustment is lost with these. I am not sure if that is accurate because I should be able to just move the ones from my SR5 to the new ones? They are spyder headlights and I think people do that.
  14. Feb 19, 2018 at 12:27 PM
    War Machine
    TXRailRoadBandit73 likes this.
  15. Feb 19, 2018 at 12:27 PM
    War Machine
    Yeah, I moved the leveling motors to mine. Pretty easy.
  16. Feb 19, 2018 at 1:26 PM
    War Machine
    By the way, when I was messing with the front bumper, I noticed that there is no skid plate. The part where the plastic on the front bolts to it was just hanging there. Is that normal?
  17. Feb 19, 2018 at 1:30 PM
    Shaggypeach
    Skid plate as in your engine cover below? It is not normal. I think non TRD ones come with a plastic ones and TRD ones has a metal one. I bought my truck used and it was missing it and I put a skid plate from RCI. If you bought it new, ask your dealer for sure. If used, it is somewhat common. OEM one comes off completely for oil changes so I was not surprised that mine was not put back on and was lost.
    https://www.tundras.com/threads/wha...3rd-gen-tundra-today.713/page-475#post-512296
  18. Feb 19, 2018 at 2:55 PM
    War Machine
    It’s been six months. Probably won’t do any good to ask the dealer. Never noticed it until now, so it may have come off during an oil change.
  19. Feb 19, 2018 at 5:14 PM
    #49
    War Machine
    Thank you sir.
    SouthBoundSteve likes this.
  20. May 5, 2018 at 4:39 AM
    #50
    War Machine
    Put some rock lights on yesterday. The ones I put on the nerf bars made too much of a spot, so I’ll probably move them. These play along with music also, which is pretty cool.
    mlucas555 likes this.
  21. May 5, 2018 at 7:38 AM
    #51
    War Machine
    Kit I used, along with a light bar harness, which had the power leads, relay, switch, and fuse included. Made the install pretty easy. Hardest part was arranging all the extra wire up out of the way.
    I left the switch under the hood, since I can turn these in and off with my phone.
    MICTUNING RGB LED Rock Lights with Upgraded APP Bluetooth Controller, Timing Function, Music Mode - 8 Pods Multicolor Neon LED Light Kit https://www.amazon.com/dp/B01IP8W254/ref=cm_sw_r_cp_tai_i_kfC7Ab37092JK
    MICTUNING MIC-B1002 LED Light Bar Wiring Harness, Fuse 40A Relay On-off Waterproof Switch https://www.amazon.com/dp/B00O72R7Z8/ref=cm_sw_r_cp_tai_i_JhC7Ab7DKQGFD
  22. May 21, 2018 at 4:15 AM
    #52
    War Machine
    Going through old pics, found the one from when I bought it. Before and after. (So far)
    C8BB6CF1-BD3D-41A2-A1B4-6EABCB07C7C7.jpg 2388D692-C223-4C5D-8F0C-F81B2FDFC17B.jpg
  23. Jun 6, 2018 at 8:42 AM
    #53
    HecticEnergy
    HecticEnergy New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    What did you end up paying for the powder coat if you dont mind my asking?
  24. Jun 6, 2018 at 10:28 AM
    #54
    War Machine
    I paid 300.00. I believe others have gotten it cheaper, but this guy was a mile from my work.
    HecticEnergy[QUOTED] likes this.
  25. Jun 6, 2018 at 11:40 AM
    #55
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Thanks! That was 300 for just the front two and you disassembled yourself? Just trying to see what’s fair before I look in my area
  26. Jun 6, 2018 at 1:07 PM
    #56
    War Machine
    It was for all four, plus the exhaust tip. I did have to disassemble them myself.
  27. Jun 6, 2018 at 1:08 PM
    #57
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    That doesnt sound too bad - thanks for the info!
  28. Aug 12, 2018 at 6:34 AM
    #58
    War Machine
    Finally got the Bakflip MX4 cover. I put it on yesterday.
  29. Aug 12, 2018 at 7:27 AM
    #59
  30. Aug 12, 2018 at 5:46 PM
    #60
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Go on pretty easy? 1 hour or so job with an extra set of hands?
