A couple tech questions
Discussion in '2.5 Gen Tundras (2014-2021)' started by RaginTxn, Jan 9, 2022.
  1. Jan 9, 2022 at 3:18 PM
    RaginTxn
    RaginTxn [OP] New Member
    Ya done messed up..
    Cypress, TX
    2018 SR5 X Series Tundra (sold) - why, why, why
    So - I didn't know quite where to put this in the garage section, so if someone knows a better place, please let me know.
    Two questions:
    1) So my new to me truck just started hyper blinking the left blinker. I replaced the front blub (looked good) - still hyper blink; replaced the rear (looked ok) - still hyper blink. Thoughts? Do I just need to try another bulb? (Sylvania Long Life coil-burner)
    2) I popped up the rear seats the other day (with the sun out) an noticed this in the center support leg
    Doesn't feel damp there - is there a leaking issue I should know about that these trucks have? (2018 SR5 CM) My '13 Ram 2500 I know had an issue with defrosting causing leakage under the rear seat. Thought I would check before tearing into things.
    thanks!
  2. Jan 12, 2022 at 7:13 AM
    RaginTxn
    Ya done messed up..
    Cypress, TX
    bringing this to the top - hoping there's someone with an idea or thought on the bolt.
    UPDATE on the hyper flash - my truck is wired for CK bulbs - got the replacement from local yota parts shop and worked perfectly. Always helpful to use the correct blub. Thought occurred to me after purchasing iHacker's wiring harness
  3. Jan 12, 2022 at 7:28 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Have you owned the truck since new?
    Can't tell from the first picture but is it just that one side or are there multiple floorboard bolts that have corrosion on them?
  4. Jan 12, 2022 at 2:00 PM
    RaginTxn
    Ya done messed up..
    Cypress, TX
    no, this is new to me. It is only the middle floorboard bolt - the other two (left and right) are perfectly fine - no rust or anything on them
  5. Jan 12, 2022 at 6:00 PM
    PNWTunrda
    PNWTunrda New Member
    Dean
    2016 Tundra
    Just checked my 2016 and the bolts are clean and dry without any rust. I would pull the back seat out and check under the carpet in that area as this is not normal.
    RaginTxn[OP] likes this.
  6. Jan 12, 2022 at 9:44 PM
    TTund16
    TTund16 New Member
    Regarding the rust:
    I recall couple of maybe related things:
    1> the 3rd brake light on top of the cab leaking and water seeping down.
    2> recall some rust pictures like yours and Toyota was fixing it. Can't remember what the issue was. Maybe some moisture inside and stuff didn't have rust proof coating.
    Do a site search and you may find them.
  7. Jan 13, 2022 at 10:25 PM
    RaginTxn
    Ya done messed up..
    Cypress, TX
