A/C not consistently cold
Discussion in '1st Gen Tundras (2000-2006)' started by smokey0810, Jun 7, 2020.
  1. Jun 7, 2020 at 11:54 AM
    smokey0810
    smokey0810 [OP] New Member
    '03 Tundra SR5 AC 4WD
    Will blow cold, then warm up slightly. Compressor is engaging. Thoughts before I dive deeper? Maybe low Freon?
  2. Jun 8, 2020 at 11:23 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Very possibly low freon. Those little refill cans at the parts house a cheap enough to start there. You can get one with dye to check for leaks too.
  3. Jun 16, 2020 at 12:28 PM
    evilrb
    evilrb New Member
    Jeremy
    Compressor going out also a possibility.
    Filled my freon twice and it was my Compressor so replaced it.
  4. Jun 16, 2020 at 1:21 PM
    Professional Hand Model
    Hand Protectors
    An A/C Failure would be a huge bummer. Sounds like when something goes bad that the proper fix is to replace everything or risk contamination of the new parts?
  5. Jun 16, 2020 at 1:27 PM
    evilrb
    evilrb New Member
    Jeremy
    Honestly, feels like it...
  6. Jun 16, 2020 at 2:23 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    Make sure the cabin air filter is clear. Leaves, and other crud, can cause the AC to feel like it's not working right. I noticed mine wasn't working quite right and found a mouse nest on top of the filter. The bad part was that some of the nest fell down into the fan and I had to pull it to get it all cleaned out. Once it was clear and a new filter was in place, everything went back to normal.
    YardBird likes this.
  7. Jun 16, 2020 at 2:24 PM
    evilrb
    evilrb New Member
    Jeremy
    First gens don't have cabin filters...
  8. Jun 16, 2020 at 2:30 PM
    Randy Morton
    Randy
    Welp, so much for that idea. :)
  9. Jun 17, 2020 at 5:02 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Is it while driving or sitting at a stop? Mine will warm slightly at idle but is consistent while driving. I chalked it up to poor airflow after having the pressures checked.
    A/C is one of those deals where it pays to have a pro look at it. The correct tools and gauges make a large difference.
