A/C illumination lights out, shifter lights too.
Discussion in '2.5 Gen Tundras (2014-2021)' started by bsavoir, Dec 4, 2018.
  1. Dec 4, 2018 at 8:42 PM
    bsavoir
    bsavoir [OP] New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    I was installing a new headunit in my truck, and when everything was connected I noticed cluster lights worked (gauges) but the A/C illumination and shifter ought do not. They run on a similar circuit why do these not work and how to fix.
  2. Dec 8, 2018 at 8:20 AM
    bsavoir
    Killeen, TX
    Solved the problem. Turns out it was an AM1 (7.5A) or the A/C (7.5A) fuse as both of those were blown. This saved me having to possibly order a new gauge cluster based on some information I seen on a 4runner form.
    Does anyone know what the AM1 fuse is used for beside the illumination of the A/C and push buttons.
  3. Dec 8, 2018 at 8:27 AM
    fastarget
    fastarget New Member
    2023 Max Platinum
    What caused the fuses to blow?
  4. Dec 8, 2018 at 9:08 AM
    bsavoir
    Killeen, TX
    No, I've usually been very very careful, but for future projects I will. I was worried for a few days about the gauge cluster having to be replace. Definitely printing off a copy of this cheat to have on hand.
    NewImprovedRon likes this.
