A/C Fan does not work and then it does
Discussion in '2.5 Gen Tundras (2014-2021)' started by kcaustin66, Dec 27, 2020.
  1. Dec 27, 2020 at 7:59 PM
    kcaustin66
    kcaustin66 [OP] New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    On my 2015 Tundra 1794 - I need some help guys, my a/c fan inside, is acting up. Sometimes it works fine, but lately it doesn’t blow. It sounds like it is working on low, but when I press the auto button it stops. So is there a way to tell if it is the resistor or the fan motor. Then the next day it will work fine after I turn it off. Then it starts acting up again.
  2. Dec 27, 2020 at 8:08 PM
    TTund16
    TTund16 New Member
    Is the a/c fan different than the heater fan? Does the heater work?
  3. Dec 27, 2020 at 8:53 PM
    kcaustin66
    kevin
    The heater works (I said a/c but I met both) when the fan is only working a little bit, and next it works great and then the fan is back to really slow again.
  4. Dec 28, 2020 at 12:59 AM
    TTund16
    TTund16 New Member
    Can you increase the blower speed manually and without using the auto? Does the fan work on the highest manual setting? Sound like the answer is no so it could be the blower motor or also check the relays.
    I am not familiar with design of Tundra but with older cars typically if the blower works only on high, the resistor is most likely bad. The new cars may have a fancier design. I'm not sure. I've had only one blower motor failure in a very old car.
    you need the wiring diagram. Maybe someone can post it.
    Doxiedad likes this.
  5. Dec 28, 2020 at 1:03 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Haven’t had a tundra one fail at work yet, but most of the newer Toyota’s have the resistor built into the blower. Chances are you just need a new blower.
    Tundra9880 and TTund16 like this.
  6. Dec 28, 2020 at 1:38 AM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    So you have auto climate control? If so it will control the fan speed based on what temp setting you have it set to. Maybe that's the issue? Can you manually increase the fan speed?
    TTund16 likes this.
  7. Dec 28, 2020 at 6:00 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    As I recall, blower motor speed on a 2015 is not set by a discrete resistance like older models. I believe the blower motor speed, and virtually everything else in the AC system is controlled by a black box called the "Air Conditioning Amplifier". There are also many other inputs to the AC amplifier that affect the blower speed, and any one of those inputs could be from faulty sensors.
    Given the labor involved and the expense of the parts, this will not be a repair where "throwing parts until fixed" is a good plan. Access to Techstream and the 2015 Repair Manual will be essential to systematically diagnose this problem imo.
  8. Dec 28, 2020 at 6:41 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    When in AUTO MODE the fan will change speed as cabin temperature changes in a effort to maintain what is set in the display. As the cabin temperature cools (A/C) the fan will slow, when you roll down your window to give a thumbs up to a fellow Tundra owner and let out the comfortable cool air, the fan will ramp up. The same applies to heat. If you adjust the fan speed manually, it will automatically cancel AUTO MODE. If you adjust the temperature setting, AUTO MODE remains. Also of note: On a cold start in AUTO MODE and heat is requested, the fan DOES NOT begin to blow at a high rate until the engine temperature begins to rise (unless DEFROST is selected manually or preset at last vehicle shutdown). In MANUAL MODE there are a fixed number of fan speeds, in AUTO MODE they are "infinite" (it's a smoother ramping up).
  9. Mar 18, 2022 at 8:58 PM
    Tundra9880
    Tundra9880 New Member
    2019 Cement CrewMax SR5
    Leveled, wheels and tires, Line X on the grille surround and bulge, Line X in the bed, Retrax rolling Tonneau cover, Flowmaster Outlaw cat back exhaust.
    good to know on this thank you!! Same issue as the OP, and found multiple YouTube vids, but one dude from A1 auto says the resistor is built in on the 2014-2019, but there’s another vid with no year listed that says the resistor is separate. Sounds like I’m in the same boat needing a new blower motor, and it looks like a fairly easy swap. Thanks!!
  10. Mar 19, 2022 at 4:59 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    https://www.tundras.com/threads/blower-motor-failing.98394/
  11. Mar 19, 2022 at 5:23 AM
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    I had the resistor failure on a taco, well kinda. Passengers screwed up the connections with they big ass feet :mad:
    From what I understand I was not the only guy with that issue and they started using "built in" resistors to get around that monkey crap
  12. Mar 19, 2022 at 2:52 PM
    Bill3648
    Bill3648 New Member
    Loudoun County, VA
    2019 Silver Sky Limited Crewmax
    Diamondback SE RCI skid plate Husky Mats WeatherTech bed-liner SCS Ray10's Eibach Stage 2 coilovers Toyo AT3 275/70/18 RAS HD Tuffy console safe
    I have a 2019 and had to replace the blower motor under the glove box at 30k
    Tundra9880 likes this.
  13. Mar 19, 2022 at 2:55 PM
    TL TRDPro LR
    TL TRDPro LR New Member
    Troy
    SoCal/Idaho
    2021 TRD Pro Lunar Rock CM
    Just replaced the resistor in my sons ‘12 Tacoma and now all settings of the blower working again… Good Luck!!
  14. Mar 21, 2022 at 8:56 AM
    Tundra9880
    Hi Bill, mine is 2019 also with 18K (not a far drive to work fortunately) did the blower motor fix your issue? Thanks!
  15. Mar 21, 2022 at 8:59 AM
    Bill3648
    Bill3648 New Member
    Loudoun County, VA
    It sure did... got it from McGeorge Toyota they had the best price. It's a 15 minute job
    Tundra9880[QUOTED] likes this.
  16. Mar 21, 2022 at 9:03 AM
    Tundra9880
    ordered one from Olathe Toyota. Hopefully it gets her soon. I saw how easy the swap was. Weird as yesterday the air worked great. Day before it had a quarter of the airflow. Always cold though. Hope this solves it. Thanks!
  17. Feb 28, 2024 at 2:31 PM
    Tundrajax77
    Tundrajax77 New Member
    2015 Tundra SR5 Double Cab
    Smack the $#it out of the area underneath the glovebox. Works every time for me... Until it doesn't
