A/C clutch failing - symptoms
Discussion in 'General Sequoia Discussion' started by clementl47, Dec 3, 2024.
  1. Dec 3, 2024 at 9:00 AM
    clementl47
    clementl47 [OP] New Member
    Little RockAR
    2006 Toyota Sequoia SR5 2WD
    No modifications done
    [2006 sequoia 2wd]
    Hello,
    I have a rattling noise between 600/1000 rpm coming from the left side of the engine, I think it is caused by the A/C clutch, since the engine doesn't knock, no exhaust shields are lose etc...
    But the problem is, my A/C works well.
    I had the opportunity to try it during the Arkansas summer and it works well when the engine is on with some rpm (1000+).
    So I'd like to know if any of you ever had a failing A/C clutch, and what was/were the symptoms of it?
    I will try to include a video of the noise as well.
    Thank you,
    Clément
  2. Dec 3, 2024 at 9:09 AM
    clementl47
    Little RockAR
