9 Speaker audio system (non JBL)
Discussion in '3rd Gen Tundras (2022+)' started by X42069, Oct 10, 2022.
  1. Oct 10, 2022 at 6:02 AM
    X42069
    X42069 [OP] New Member
    M
    Southwestern Ontario Canada
    23 SR5 CrewMax TRD Off Road 6.5ft box
    I did a search and couldn't find a dedicated thread.
    Can anyone post some reviews of the 9 Speaker audio system that comes on the SR5 CrewMax models?
    I test drove a limited which I thought had the JBL system however I'm not sure you can get a limited with the JBL in Canada?
  2. Oct 10, 2022 at 6:25 AM
    Boats N TRDs
    Boats N TRDs New Member
    Travis
    2022 Tundra Limited HV TRD OR
    Chrome delete
    I've owned two 3rd gen trucks, one with non-JBL and one with. Here are my thoughts comparing the two.
    If you like your music on in the background at low volume or listen to podcasts/talk, the non-JBL system will sound better. The JBL system has a lot of low end bass at lower volume. The non-JBL sounds better at lower volumes.
    If you like to turn it up, the JBL option is the way to go. The non-JBL system can't really go beyond volume level 25 without sounding like crap. I crank my JBL system to 35 and it still sounds clean.
    If you're an audiophile, you still may not be completely happy with the JBL system. They didn't use much, if any, crossovers and it sounds like they're sending full frequencies to all speakers. The 2-3 inch speakers on the dash can't handle all the bass they send it. I'm sure they're sending high end to the sub too.
    The non-JBL system is easier to replace should you want to upgrade to a really nice sounding system.
    Skidmarcx and Tundra ATL like this.
  3. Oct 10, 2022 at 6:28 AM
    X42069
    M
    I appreciate the detailed response.
    I will be getting the non JBL system and am pleased with what you have said about it. I do plan to upgrade, ass sub and amp down the road
  4. Oct 10, 2022 at 7:59 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I don't know about your 2022 but the non JBL Gen 2.5 have capacitors on the dash speakers.
    They aren't playing a full signal, they are designed as high mids and tweeters..
    As well the lower front door speakers don't get high frequencies.
    There is a crossover in the under seat amp for the lower door speakers
    2063C203-0B01-444E-9D08-304E75F398C4_zps_391e7ead6eb3fb9d75483db96c0e9162e24fa762.jpg
    But none of that matters to me.
    I've replaced the HU, amp, all door speakers, and added a twin 10" sub enclosure in my 2014..:thumbsup:
    The Gen 2.5 Entune, both JBL and non-JBL is shit..
    Maybe the 2022 sounds better..:confused:
  5. Oct 10, 2022 at 8:07 AM
    Boats N TRDs
    Travis
    Chrome delete
    I haven't taken the stereo apart yet, so there may be some capacitors/crossovers in action, but it sure doesn't sound like it. I can clearly hear the bass coming from the front of the truck, yet the sub is in the back. You can actively hear the bass lose stability when a clean low range is going on and mid-range kicks in.
    Granted, I drove my last truck for 10 years and the very first thing I did was rip out all of the audio after the head unit and replaced with really good equipment. I miss my last truck's stereo for sure! I think I just got spoiled with my last stereo and the JBL system just doesn't come anywhere close.
  6. Oct 10, 2022 at 8:13 AM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    You’ll need a platinum for the JBL option in Canada, limited dose not get it.
    1lowlife likes this.
  7. Oct 10, 2022 at 1:09 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    The low end you hear in the front is coming from your door speakers..
    Those are technically woofers and low midrange if it is anything like the Gen 2.5.
    I'd guess the 2022 HU/amp has the same crappy bass roll off the previous Entune.
    It protects their cheap low-ohm mini-magnet speakers from distortion.
    I just looked over the schematic of the 2022 12-speaker JBL and 6 & 9-speaker non-JBL systems.
    They are a bit different from the Gen 2.5 Entune, which is shit...:rolleyes:
    Even the 2022 wiring diagram doesn't refer to the JBL as being 'JBL' like it did on the Gen 2.5.
    It refers to the difference as being:
    Non-JBL w/o sub box- Audio System (Built-in Type Amplifier)
    JBL w/ sub box - Audio System (Separate Type Amplifier)
    I'd think with everything the 2022 HU probably does (settings, etc.) it would be more difficult to just gut and replace everything.
    I swore when I bought my 2014, non-JBL, I wouldn't touch the audio system.
    That lasted about 6 months and then I gutted it...:cool:
  8. Oct 10, 2022 at 3:10 PM
    brucega7x
    brucega7x New Member
    2022 Tundra SR5 CrewMax 4X4
    Neither are amazing. The base system is decent enough for most.
    Replacing all of them regardless of which ones is the best bet if you really want the best.
    Yaboy likes this.
  9. Mar 15, 2023 at 4:41 PM
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    Exactly what I was thinking.
  10. Mar 15, 2023 at 4:43 PM
    Markysharky
    Markysharky New Member
    For low volume it sounds pretty clear (non jbl). For higher volumes I get some door rattle that’s pretty bad (volume 35 or higher). Sounds mediocre at best.
  11. Mar 18, 2023 at 1:28 PM
    RatPanda
    RatPanda New Member
    Ryan
    2022 Tundra 4x4 CrewMax 5.5
    Overall…I love this truck and try not to make negative posts in general. But…imho…the stereo is just horrible. I’m very disappointed. I feel like I’m blasting an AM transistor radio (might be an exaggeration). And agree with above post…real bad rattles/vibrations when I turn it up. I’m going to hunt those down when the weather gets better…
  12. Mar 18, 2023 at 2:13 PM
    DaxM
    DaxM New Member
    Temple, TX
    2023 Wind Chill Pearl Capstone
    I agree, mine sounds like an Oldsmobile 88 with a couple of woofers in the trunk. If I turn surround on, it sounds worse but with less rattles. Guess i'll be taking the door panels off at some point and going at it with some foam tape.
    RatPanda[QUOTED] likes this.
  13. Mar 18, 2023 at 5:15 PM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    I really don't like how it sounds down low. Not interested in turning it up much.
  14. Jul 9, 2023 at 5:29 AM
    obgod3
    obgod3 New Member
    NC
    2023 Tundra Limited
    Well Im going to try to put some life into this thread. I dont like my non-jbl system. It’s the one thing on my truck I just do not like at all. Im going to have to spend some money. Been lookin at Taco Tunes stuff but seems complicated. So might find an audio shop to do some upgrades. My JBL in my 2008 Tundra was good for me, my buddies JBL in his 2018 was not very good. But in my 2023 the Non-JBL is not good, looking for suggestions.
    Allrsdup and Yaboy like this.
  15. Jul 9, 2023 at 5:44 AM
    trdandglocks
    trdandglocks New Member
    2022 Tundra Platinum
    I also really dislike the Non-JBL system in my truck. Something I’ve been reading and will probably do is this, I think it might make it a little better until I’m willing to spend more money on it.
    https://www.beatsonicusa.com/pa2t2.html
    obgod3 likes this.
  16. Jul 9, 2023 at 7:01 AM
    Breathing Borla
    AZ
    The gen 3 jbl is way better than the gen 2.5 which was just 100% total shit. It has some power and some clarity and sounds decent at low to low-mid power levels
    they both suffer from the jackass who tuned them and decided all the bass should come from the door speakers and not the sub
    i did a total rip out of the gen 2.5 , not sure what I want to do for this one but this one will not involve taking out the head unit , the stock screen system is really nice super fast and the clarity of the screen is the best I’ve seen
  17. Jul 9, 2023 at 7:14 AM
    dogsleds_t100_tundra
    dogsleds_t100_tundra New Member
    '23 Tundra SR5 TRD OffRoad AG and '97 T100 4x4
    275/70/18 AT3, Elka IFP 2.0, Aftermarket Speakers, Sub, Amp. Ceramic Window Tint, Color matched grill surround and rear bumper panels, Orvis Backseat Protector for K9s, OEM Black Exhaust Tip, OEM Black Tailgate badge insert.
    Following. Non-Jbl here. Been chatting with local installer over the past several weeks to decide what i want to do and comfortable to spend, to upgrade sound of non-jbl system in my case. Made appointment several weeks ago to drop off the truck for a day. Going to swap speakers and add small hideaway sub under passenger seat. Hopefully it will work out well. It is scheduled for next week.
    Allrsdup likes this.
  18. Jul 12, 2023 at 1:00 PM
    obgod3 likes this.
  19. Jul 12, 2023 at 6:28 PM
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    Anybody here install this power amp already to see if it makes any improvements?
    Suhail likes this.
  20. Jul 12, 2023 at 6:35 PM
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    While the non JBL isn't great in my 23, it's night and day better than the non JBL in my 19 and 21. I had a visit to JRT for my 21 and miss it but this one I'm thinking I'm just going to leave alone. I hate it but not willing to give up any storage space for speakers.
  21. Jul 13, 2023 at 11:44 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    I have the non-JBL "premium audio" included in a package... not sure if that is 9 speakers or 12 speakers or whatever... and I am mostly happy with it. At least happy enough not to mess with redoing everything like I usually do.
    Allrsdup and Nomoredomestics like this.
  22. Jul 13, 2023 at 5:56 PM
    RatPanda
    RatPanda New Member
    Ryan
    Check out the pinned "WHAT HAVE YOU DONE TO YOUR 3RD GEN TUNDRA TODAY?" thread or search for Beatsonic, there are others on the forum that have tried it. Let us know how it works out. I'm seriously considering it.
  23. Jul 13, 2023 at 9:01 PM
    Allrsdup
    Allrsdup New Member
    Joe
    24 Lunar Rock Limited crewmax trd ord
    Would you say the 9 speaker non jbl in the 23 is better or worse that=n the jbl in the previous gen? I had a 21 trd pro and the jbl was not good
    if my new 23 with the 9 speaker non jbl is at least that or slightly better i can live with it for a while. my 23 comes in next week.
  24. Jul 14, 2023 at 2:04 AM
    Nomoredomestics
    GA
    2023 TRD Sport 4x4
    Let us know. . . But I would imagine it's just as good. .
  25. Jul 14, 2023 at 9:32 AM
    Suhail
    Suhail New Member
    S
    Ontario Canada
    I installed the beatsonic amp with front and Rear door speakers replaced with JL Audio. Makes a huge difference and better sound in clarity and loudness compare to JBL system.
  26. Jul 14, 2023 at 4:29 PM
    obgod3
    obgod3 New Member
    NC
    2023 Tundra Limited
    I dont know about all of them but my 08 Tundra Limited with the JBL is/was much better than the base 9 speaker system in my ‘23 limited.
    Nomoredomestics likes this.
  27. Jul 14, 2023 at 5:06 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    what model speakers did you go with from JL Audio?
    Did you replace all 9?
  28. Jul 15, 2023 at 1:47 PM
    Hella Krusty
    Hella Krusty New Member
    I said the exact same a week ago and got roasted for it LOL
    Yaboy[QUOTED] likes this.
  29. Jul 15, 2023 at 4:38 PM
    G3ardnut
    Joe
    Canada
    Yes, some details on this would be great.
  30. Jul 15, 2023 at 5:58 PM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    It’s true
