9 quarts of oil wow
Discussion in '2.5 Gen Tundras (2014-2021)' started by georgie, Oct 18, 2019.
  1. Oct 18, 2019 at 4:09 AM
    georgie
    georgie [OP] New Member
    Just had my 2019 5.7 new toyota care done 2nd time . I looked at the paper work this time they noted 9 units of oil with oil filter. I checked my level after i got home with the engine hot and sitting 5 min the level was dead nuts on the top hole.
  2. Oct 18, 2019 at 4:19 AM
    FUBAR
    FUBAR New Member
    2019 Tundra TRD crewmax
    Possible, but the more likely explanation is they charged Toyota for 9 quarts and put the correct amount in. I don't think they have a way of charging for partial bottles so they just round up. Most people here say it's between 7.9 and 8.1 quarts of oil. As long as it's not low or overfilled you are good so at least they didn't screw that up.
  3. Oct 18, 2019 at 5:07 AM
    Trikerider
    Trikerider New Member
    2015 Limited CM
    When I change my oil and filter 8.5 qts puts it right at the top line.
    Prostar 190 likes this.
  4. Oct 18, 2019 at 5:37 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Exactly 8 qts for me at top of line. Not sure how sensitive the dip stick is, maybe it wasn’t seated all the way? Maybe they spilled some? An extra quart seems a lot
    B737 likes this.
  5. Oct 18, 2019 at 8:31 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    They must have poured a quart in before putting the drain plug back in and felt they needed to charge you for it. 7.9 qts. (8.0 qts. to make it easy) is what is specified.
  6. Oct 18, 2019 at 8:47 AM
    915tundra
    915tundra New Member
    LEE
    WEST TX
    2017 Tundra TRD Pro
    toyota tech here, guys they changed the capacity.... 2018+ use 8.5 qts, the 2017- use 7.9
  7. Oct 18, 2019 at 8:56 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    By golly, you are correct, just checked the manual. I have been shorting the truck by 1/2 quart over the past 4 oil/filter changes (2018 here).
    What changed to increase the oil quantity requirements?
  8. Oct 18, 2019 at 11:25 AM
    Shephard_Of_The_Tundra
    Shephard_Of_The_Tundra DIY try guy
    Corpus Christi, TX
    2016 Black Tundra SR5 4.6 DC 2WD
    Morimoto 2 stroke H4 LED Headlight Bulb VLEDs 3157ck Amber Triton V6 TurnSignal Auxito LED reverse bulbs OEM Toyota LED smoked fog lights Auxito LED T10 license plate bulbs Auxito LED T10 Side marker headlights LASFIT LED T10 3rd brake light Xenon Depot T10 LED Bed/Brake Lights TRD Off-Road Black/Chrome Wheels Bridgestone Duellers 255/70/R18 Front & Rear TRD Sway bars MBRP Dual side exhaust exits Drop-in K&N air filter TRD air flow accelerator Toyota Rubber floor liners OEM Rear under seat storage box Kenwood DMX7706S head unit TRD Shifter knob Center console organizer tray Dual USB fast chargers center stack
    Have a '16 here, you think it would be better to put the 8.5 in mine? Mine takes 8 now as it is, but if these motors are the same....you know
    915tundra[QUOTED] likes this.
  9. Oct 18, 2019 at 11:30 AM
    915tundra
    LEE
    WEST TX
    2017 Tundra TRD Pro
    At the dealership I put 8.5 in all 5.7 from 07-present
  10. Oct 18, 2019 at 11:31 AM
    Corpus Christi, TX
    4.6 any different?
  11. Oct 18, 2019 at 1:46 PM
    915tundra
    LEE
    WEST TX
    2017 Tundra TRD Pro
    4.6 is the same after 2011. before that the 4.6 was a old style engine w timing belt, the new 4.6 is basically a smaller 3urfe
  12. Oct 18, 2019 at 2:02 PM
    15whtrd
    15whtrd Mr. Blonde
    The old 4.6 L was a 4.7 L LOL. But I knew what you meant sorry :D
  13. Oct 18, 2019 at 2:09 PM
    This is exactly what I have to do.
  14. Oct 18, 2019 at 2:09 PM
    915tundra
    LEE
    WEST TX
    2017 Tundra TRD Pro
    lol! Omg your right, I totally forgot, since they are getting older rarely do we see them at the dealership. I guess they take them to independent shops after warranty is up
    15whtrd likes this.
  15. Oct 18, 2019 at 2:10 PM
    Probably only change is just what they print in the book.:D
  16. Oct 18, 2019 at 2:14 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    It is odd because right after I read that I should have put 8.5 quarts in I checked the oil (about 500 miles since last oil/filter change) and the level was just an RCH below the top dimple. I have always used 8 quarts for O/F changes. It doesn't look like I have been under filling it. Go figure.
  17. Oct 18, 2019 at 2:15 PM
    Don't forget those red one are pretty course. Lol
