8" ready lift and coil overs?
Discussion in 'Suspension' started by SullyMoto19, Jun 8, 2018.
  1. Jun 8, 2018 at 9:01 AM
    SullyMoto19
    SullyMoto19 [OP] New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    Im thinking about pulling the trigger on some coil overs, but no one can give me a straight answer if they will fit correctly on an 8" readylift.
    any big lifts want to throw some knowledge my way?
    seems like it wouldn't be as problem since the readylift reatains stock coils. should be an evan swap I would think. adjusting the coils for more lift would just throw my UCA angles a little out of wack right?
    Jsena and TXRailRoadBandit73 like this.
  2. Jun 8, 2018 at 12:35 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    I'm in the same boat as you and have made the same assumptions. I'm fairly certain there shouldn't be any issues with fitting them, just don't know how much adjustment of the coilover the factory upper arms can take, before alignment issues present themselves.
  3. Jun 8, 2018 at 12:55 PM
    SullyMoto19
    Tyler
    Houston, Texas
    I have aftermarket UCAs (Zone) so I have plenty of room I think. Even if I cranked them up the full 2in, I don’t think it would make a huge difference
  4. Jun 13, 2018 at 7:10 PM
    kirk1963
    kirk1963 New Member
    I read a FB post by Mike M from Readylift and he said a guy could eliminate the spacer in the 8" kit and use a toytec 3" coilover. I'll see if I can find it
    Jsena likes this.
  5. Jun 13, 2018 at 9:39 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    No way!
  6. Jun 13, 2018 at 9:40 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    You can call ADS and they can make one for you that size
  7. Jun 14, 2018 at 3:23 AM
    kirk1963
    kirk1963 New Member
    No idea how good this info is, probably worth a call to Readylift:
