7" lift kit??
Discussion in 'Suspension' started by Ron Burgundy, Mar 22, 2015.
  1. Mar 22, 2015 at 3:43 AM
    Ron Burgundy
    Ron Burgundy [OP] New Member
    Ronald
    Houston tx
    2015 Black crewmax 4x4
    Hi guys I'm new just picked up a 15 sr5 4x4 Crewmax and looking to go 7" BDS coil over kit and running 37/12.5/20 toyo RT tires with fuel 20x9 + 20 offset. My question is pro and con about going that high, I notice a lot of guys on the forum doing 4" lifts why not bigger? With that in mind BDS says I can go 37 on tires, will it rub ? I'm looking for more of an aggressive stance when I pull up to the light I don't want to be looking up at another guys truck that's why I kinda want to go bigger on the lift.
    Junior 88 likes this.
  2. Mar 22, 2015 at 8:18 AM
    I won't go any higher than 3.5"-4" personally. Why? I want to be able to fit into my garage, and some parking structures if needed.
    Anything at 6"+ you will be cutting the frame, which will void the frame warranty.
    Most guys at 6" + run 35-38" tires on 20" wheels.
    I like the look of the 7" BDS lift, and at the end of the day you have to do what you think looks the greatest.
  3. Mar 24, 2015 at 9:39 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Sounds like you want this
    Yes that's my 3" lifted tundra with 35" tires in the back.
    CJ21, trayday and JC303 like this.
  4. Mar 24, 2015 at 10:26 PM
    Ron Burgundy
    Ronald
    Houston tx
    That's a great picture ! I cam really see the difference.
    CJ21 likes this.
  5. Mar 25, 2015 at 1:43 PM
    csuviper
    Broomfield, CO
    That is a 12" lift with 40s I believe. @Sean266 is that what you remember?
  6. Mar 25, 2015 at 7:36 PM
    Yessir
  7. Mar 25, 2015 at 8:32 PM
    JC303
    JC303 Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    If only that could fit in my garage!:dancingbacon:
  8. Mar 25, 2015 at 9:16 PM
    That's what she said.
    IsaiahCanada likes this.
  9. Mar 26, 2015 at 11:34 AM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
    2011 Spruce Tundra TRD SR5 2WD
    3" Leveling Kit 3.5" Spindle Lift 4" Rear Blocks AirAid Intake 20" XD Monsters w/ Nitto Grapplers 1" wheel spacers for rear Magnaflow Exhaust Pro Comp Shocks for rear
    the best part of that picture is its parked in front of a jamba juice
  10. Aug 11, 2022 at 5:49 AM
    Junior 88
    Junior 88 New Member
    Junior
    18 tundra Sr5
    7inch bds on 35s
    I have the 7in BDS lift on 35 ko2. No regrets.
