7 Cubes in Parallel...Wiring help?
Discussion in 'Lighting' started by back_cast, Feb 15, 2022.
  1. Feb 15, 2022 at 2:21 PM
    back_cast
    back_cast [OP] New Member
    Denver, CO
    Hello,
    I'd like to install some lights on a bumper that will be arriving soon and had some questions about wiring up 7 Squadron Sport cubes in parallel to the factory fog light switch that comes off the steering wheel column on a 2018 Toyota Tundra.
    Could you help me to understand what I may need to wire that up? I'd like them to all come on at once, which would be roughly 30W x 7 = 210W. Call it 250W.
    Can I link the lights up with splitters? Any additional relays to worry about? General thoughts or concerns?
    Looking at these made by @Baja Designs
    https://www.bajadesigns.com/products/squadron-sport-led-driving-combo.asp
  2. Feb 15, 2022 at 2:24 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Is it Friday? Why would you ever wire them in series?
    You would need to wire them in parallel and use at least a 30 amp relay triggered by the hot going to the fogs after the switch.
  3. Feb 15, 2022 at 2:28 PM
    back_cast
    Denver, CO
    Thanks French Toast, it's been a hot minute since Elec Eng class lol
    Edits made - Parallel not Series
  4. Feb 15, 2022 at 2:30 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Can i ask a dumb question? Why not just get one lightbar? Or do you only want to use the fog light stalk?
  5. Feb 15, 2022 at 2:31 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Doesn’t Baja sell linkable lights that would make this easier?
    Edit: they do, but it might not be as tight of a fit for your application
  6. Feb 15, 2022 at 2:31 PM
    back_cast
    Denver, CO
    Because I already have two amber squadron sports in the fog locations currently lol and they'd look small on the A-pillar in my opinion
    Need to look into that
  7. Feb 15, 2022 at 2:32 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    As @FrenchToasty said, use a relay triggered by the fog switch. I would take that output and send it to a distribution block w/ fuses. Fuse and wire size accordingly to protect yourself.
    FrenchToasty likes this.
  8. Feb 15, 2022 at 2:33 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    You're going to want to run those lights in parallel ( all pos (+) together & all neg (-) together) the total would be 14a @ 12v. Put in a relay for sure. Trigger the relay from the lights you want to turn them on and run a 15a dedicated fused line to the battery (+) to power the relay and connect the POS of the lights to the relay output. Ground the neg of the lights to a solid ground, preferably with the relay ground.
  9. Feb 15, 2022 at 2:36 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Would this make your life easier?
    https://www.bajadesigns.com/products/XL-Linkable-LED-Lights.asp
  10. Feb 15, 2022 at 2:37 PM
    back_cast
    Denver, CO
