6inch pro comp lift-3 inch rear shackles
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bulldogs85, Jul 6, 2016.
  1. Jul 6, 2016 at 5:10 AM
    Bulldogs85
    Bulldogs85 [OP] New Member
    Gabe
    2014 tundra Platinum crew max
    6inch stage 1 pro comp, Magnaflow Dual Exhaust, AFE CAI
    so after work I received my rear shackles, poly bushings and CB drop kit. I suddenly came to a halt. My question is with me having a 6inch lift stage 1 with pro comp, do I need to remove my rear blocks and AAL?
  2. Jul 6, 2016 at 6:22 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    If you previously had 3" block and now your adding a 3" shackle the. Yes the block needs removed unless you want the rear to be way too high.
  3. Jul 6, 2016 at 6:32 AM
    Bulldogs85
    Gabe
    I started on my passenger side, by removing it. Then I went to put on my factory U-bolts when they were a pain in the A** to get in the slotted holes so I stopped there. Do I remove pro comp AAL in order for that to align in the slotted holes?
  4. Jul 6, 2016 at 6:49 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    unless i'm reading this wrong you are intending on using the shackles to replace 1 of the 2 ways you're lifting the rear of your truck?? if this was the case i'd probably ditch the blocks only because they're easier to remove than pulling the leafs apart to remove the aal. however, i would guess a 3" shackle is probably closer in installed height to the 1.5" you get from an add a leaf so it'd make more sense to remove whatever is going to give you what you are after in terms of rear lift height.
    also, before owning my tundra i installed an aal on the tacoma i had and found that disrupting the original leaf pack caused obnoxious squeaking over everything even though i greased between the leafs as per instructions so beware.
  5. Jul 6, 2016 at 7:49 AM
    Bulldogs85
    Gabe
    Same what I was thinking, just playing it safe on my end. Never removed leaf packs, simple or a pain?
  6. Jul 6, 2016 at 8:04 AM
    PlatinumPro
    removing the leafs is as simple as can be. repacking is a pain in the ass and i hope to never have to do it again as it just resulted in the squeaking i mentioned.
    in all honesty i pretty much hated everything about my aal aside from the lifted appearance. along with being excessively loud it also bucked hard on small bumps (speed bumps especially) and i felt i would have been better off with shackles which at the time weren't an option for the tacoma... still might not be?
  7. Jul 6, 2016 at 8:35 PM
    Bulldogs85
    Gabe
    Just finished installing. Talked to coach builder , said everything stays. Sits they way I wanted it to.
    CaptTyler likes this.
  8. Jul 7, 2016 at 6:47 AM
    PlatinumPro
    that's terrific news man. make sure to fire up a photo of the finished product
