69,000 miles on a 2005 Limited too low?
Discussion in '1st Gen Tundras (2000-2006)' started by dprechtl, May 13, 2025 at 3:08 PM.
  1. May 13, 2025 at 3:08 PM
    dprechtl
    dprechtl [OP] New Member
    Yesterday
    I am in the market for a 2005 or 2006 Tundra. I have the opportunity to buy one from an older gentleman who is a family friend. He is asking $14k for a 2006 Limited with 69K miles on it.
    I am a bit apprehensive to buy a 20+ year old truck with that low of mileage on it. Does anyone have any advice on if I should avoid it because it's so low in mileage?
    https://imgur.com/a/N13MljC
  2. May 13, 2025 at 3:11 PM
    LightTheBeam
    LightTheBeam New Member
    Sacramento, CA
    2024 Tundra Limited
    Bone stock (for now)
    What part of the country are you in? If you're not in an area that uses salt brine on the roads the frame should still be ok.
  3. May 13, 2025 at 3:17 PM
    dprechtl
    Yesterday
    I do live in an area prone to rust, but that's not really what I'm worried about. I'm more so worried about the other things that can go wrong when a car sits for a long period of time- light gaskets shrinking, sludge in the engine, etc.
  4. May 13, 2025 at 3:18 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    From the looks of that engine, in particular bolts and screws, if it was in my neck of the woods, that ole man and I would be dickering. I personally would have no qualms in buying a 64K mile Tundra, after I listened to it and checked frame.
  5. May 13, 2025 at 3:24 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L “Best Cab”/AC Limited 51k mi
    Low-mileage owner here. I assume your concern comes from the sticky thread (or perhaps your own personal experience with other motors!). Either way, it's a valid concern. I haven't opened mine up to see if there is anything gummed up or scummy in the valves, but my truck runs like a top and always has. I would just buy it, change all the usual fluids and start putting some miles on that b.
    Black Wolf and BubbaW like this.
  6. May 13, 2025 at 3:46 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    Nah. Buy it and run a can of Liquid Moly engine flush through for the next 3-4 oil changes. This assumes all of the other gotchas check out. I.E. timing belt, LBJs, frame rust.
    Black Wolf likes this.
  7. May 13, 2025 at 3:59 PM
    Fragman
    Fragman New Member
    TX
    2006 Tundra DC SR5 2WD V8
    Ditto on the timing belt, LBJ's. Also radiator. The fellow may not have got those done as the mileage is so low, but age matters too.
    I'd run some of that Valvoline Restore and Protect oil through it (or whatever it's called). I've seen consistently good reviews for it for cleaning up engines. AT205 will help any dried out seals, though if your oil is clean, I would do a few hundred miles with the AT205, then do the oil change to the Valvoline stuff.
    Pretty much what I decided to do with mine (got it at just under 149k). Only because I have no real history on mine, and although it LOOKS well maintained, and all fluids I have changed so far looked to not be anywhere near past their useful life, thought I might as well. I wasn't in a rush to do the oil change as what it had looked clean and was 'full', just reckoned I might as well run the Restore and Protect oil through it when I did it's oil change over this past weekend.
  8. May 13, 2025 at 4:07 PM
    2WD? 4WD? That truck looks pretty cherry in the photos. the mileage would not scare me depending on the story. Drove it several times a week for more than 15 mile trips? No sweat. Drove it regularly for a number of years, then parked it for 8 years, then drove it short trips a couple times a month or year? Potential problem. People also tend to focus on miles for vehicle health when age has just as much to do with it. Timing belt status? Radiator replacement?
