60K service
Discussion in '2.5 Gen Tundras (2014-2021)' started by k9shag, Aug 28, 2019.
  1. Aug 28, 2019 at 10:28 AM
    k9shag
    k9shag [OP] New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    I just had a 55K oil change and rotation. My service advisor stated at 60K the injector service $106, induction service, $120 and PCV valve change $295 are due. Does the PVC valve change seem high for a 5.7?
  2. Aug 28, 2019 at 10:33 AM
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    Yes, in my opinion, it’s a $6 part Fromm cool springs, and is easy to access. Unless they are doing something idk about too
  3. Aug 28, 2019 at 11:28 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Every last bit of it smells like a smoke job to me.
    I know tech changes. But I still drive my 1997 Toyota T-100 (3.4L V6) and have never done a fuel injector service or (just for the record) a mass air flow sensor cleaning. At 262,000 miles and still rockin' the juke box.
    Chucho likes this.
  4. Aug 28, 2019 at 11:44 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Yep, blowing smoke up your backside. Not sure what induction service is but the other 2 are only needed if not running right. They are just to pad the dealers bottom line
  5. Aug 28, 2019 at 11:58 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Tried doing this to me at a 30k service I didn’t even give them an answer just grabbed my keys and walked away.
    B737 likes this.
  6. Aug 28, 2019 at 12:06 PM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    At 60k, they should change oil and filter, air filter, cabin filter, and rotate the tires. If the truck is ran in hard conditions or tows a lot, then possibly a drain and fill or the trans fluid and that is about it.
    Just had the 60k done our 4 runner, should be about the same for Tundra. 3 dealers quoted anywhere from $189 to $249. Went to the cheapest for the first time and they did everything mentioned above in less than hour besides trans drain and did a good job surprisingly!!!
  7. Aug 28, 2019 at 4:28 PM
    Dano8855
    Dano8855 New Member
    2018 Tundra Limited
    Agreed. That stuff doesn't need to be done unless the truck is running rough. Put some fuel injection cleaner in the truck a few times a year and you should be good.
  8. Aug 28, 2019 at 4:44 PM
    k9shag
    Tony
    Midland, NC
    Thanks. I run Lucas fuel injector cleaner every three or four tanks. I have no issues. Really wasn't sure about the pvc valve
  9. Aug 28, 2019 at 4:49 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    :eek::eek2::eek::eek2:
  10. Aug 28, 2019 at 4:51 PM
    k9shag
    Tony
    Midland, NC
    To often?
  11. Aug 28, 2019 at 5:09 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    NO.
    Way way way way way way to often. IMHO.
    Just run a tank of Chevron with Techron instead. Or, if you're running Chevron pretty consistently then just........keep going and stop the additive and save yourself all the money.
  12. Aug 29, 2019 at 6:42 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    What about MMO (Mystery Marvel Oil)? One fuel tank every oil change ran with MMO...any thoughts/concerns with that treatment?
