6 Speed Manual Shift- Sloppy Shifter
Discussion in '1st Gen Tundras (2000-2006)' started by SeaBass8, Sep 24, 2019.
  1. Sep 24, 2019 at 6:57 PM
    SeaBass8
    SeaBass8 [OP] New Member
    2005 RCLB V6 6spd 4x2, 2002 RCLB V8 A/T 4x4
    Plans
    So I bought this Tundra recently and have been addressing a few maintenance issue. One of which is a wicked sloppy shifter. So I went to the Google which told me my problem is worn out shifter bushings. So I went to my local Toyota Dealer, Toyota does not sell the bushing needed separately for what ever reason. So I got them from Core Shifters online and swapped them out. That helped tighten it up a bit however I discovered the true issue is with the stick itself. It appears to be two pieces joined together and the top part of the shifter wobbles quite a bit.
    Has anyone else experienced this in the manual shift tundras?
    Toyota wants 235$ for the piece. I'm considering buying a Hurst short shift kit from Core Shifters instead which I think would be a cool upgrade anyways.
    Also, does anyone else love the fact that these trucks came with a six speed manual gear box? I certainly do!
    15whtrd and Darkness like this.
  2. Sep 24, 2019 at 7:04 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    I had similar issues with my 09 Tacoma with a six speed manual trd short throw shifter. I think urd made one that was supposed to be solid shaft.
  3. Sep 24, 2019 at 7:08 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Is there a set screw where the two join or is it like a roll pin? Or somehow shim where the gap is making it wobble, or dare I say, throw a tack weld on that Girl!
  4. Sep 24, 2019 at 7:12 PM
    SeaBass8
    Plans
    I think the top piece is plastic so welding not and option lol
  5. Sep 24, 2019 at 7:15 PM
    SeaBass8
    Plans
    It doesn't appear the URDs short shift kit includes the stick itself...
  6. Sep 25, 2019 at 5:40 AM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Yup you're right. Try the Hurst brand one. The only complaint I had about the trd short throw I had was it was difficult to shift into reverse. No big deal if you are used to it but when other people drive the truck they get confused.
  7. Sep 25, 2019 at 7:10 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Sloppy Shifter
    That was my stage name when I had to do unsavory things to put myself through college.
  8. Sep 25, 2019 at 10:00 AM
    SeaBass8
    Plans
    HAAAAA!!!!!! Well played!
    hagrid[QUOTED] likes this.
  9. Aug 4, 2020 at 6:37 PM
    dgockley
    dgockley New Member
    2005 Tundra AC Manual
    How did you resolve this? End up with the Hurst replacement or Toyota?
  10. Aug 4, 2020 at 6:41 PM
    biebs96
    PA
    Toyota’s are a two piece shifter. The rubber is to reduce transmission noise inside the cab.
    Adding a solid shifter will add a ton of rattles and unwanted noises inside the cab and translated to your hand.
    A short shift kit will “tighten” it up, but Toyota shifters are typically that way.
  11. Aug 4, 2020 at 8:41 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I thought it was SHORT SHIFTER :D
  12. Aug 4, 2020 at 9:04 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Damn, I've had to use this a lot lately...
  13. Aug 5, 2020 at 3:17 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Cool thread!
  14. Aug 6, 2020 at 5:29 PM
    SeaBass8
    Plans
    My Tundra shifter flexes at least an inch to either side. When you remove the shift lever you can really see the issue is in the shift lever. To me it seems excessive. My 97 4Runner shifter is tight like a traditional shifter and feels proper. I had another member pm me that he thinks this is a known issue with the Tundra shifters and a lot of them are like this.
  15. Aug 6, 2020 at 5:34 PM
    SeaBass8
    Plans
    I did not get the Hurst shifter. Replacing the two bushing did help a lot! But not totally. I guess I'm going to live with it at this point.
    I would love to hear other manual shift owners chime in on their experiences.
  16. Aug 9, 2020 at 7:01 AM
    Professional Hand Model
    Hand Protectors
    Darkness likes this.
  17. Nov 21, 2021 at 4:02 AM
    tailfinjoe
    tailfinjoe New Member
    2006 Tundra 6 speed 8ft bed
    none at this time
    I also have a 6 speed manual transmission and I like it but it’s sloppy compared to my corvette and the reverse is up and on the right and the tundra is on the left! I know that’s not a fair compassion but after reading this blog has anyone come up with a kit or a shifter that is tight and smooth? Thanks Joe
  18. Nov 21, 2021 at 9:45 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    I'd check and see if one of the 3 different size delrin shifter bushings offered by marlin crawler fit.
    It would be way more solid than the rubberish OEM one, even when it's new.
  19. Nov 21, 2021 at 11:45 AM
    tailfinjoe
    none at this time
    Thank you do you have a link for these bushings ?
  20. Nov 21, 2021 at 3:01 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
  21. Nov 21, 2021 at 4:12 PM
    I get a little bummed any time these older posts get bumped and I see PHM in one of the previous half dozen replies.
    bmf4069 and FrenchToasty like this.
  22. Nov 21, 2021 at 4:20 PM
    FrenchToasty
    Mo
    Bone stock
    bmf4069 and shifty`[QUOTED] like this.
  23. Nov 21, 2021 at 5:41 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Twice in one thread! Sweet!
    SouthPaw and FrenchToasty like this.
