6" lifted tundras running a sway bar..
Discussion in 'General Tundra Discussion' started by andy9743, Jun 25, 2017.
  1. Jun 25, 2017 at 5:16 PM
    andy9743
    andy9743 [OP] New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    Anyone have a sway bar on their 6 inch lifted truck? Trying to install a hellwig on my truck and the end links seem to short. They are measuring 19 inches and I'm at 21 inches needed. However I am at full droop, as it's on my 2 post lift. Should I have the rear end under weight? That might make up the difference.. any info is appreciated!
    Thanks
    Andy
  2. Jun 25, 2017 at 5:24 PM
    andy9743
    andrew
    nw ohio
    Thanks for reply. So the trucks weight should be on it when installing?
    GNTundra likes this.
  3. Jun 25, 2017 at 5:31 PM
    andy9743
    andrew
    nw ohio
    Your links have not been lengthened?
  4. Jun 25, 2017 at 5:31 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Here is a photo showing my TRD rear sway bar after it was extended and powder coated. IMG_4524.jpg
  5. Jun 25, 2017 at 5:37 PM
    Have a rough country 6" lift n bought a used trd sway bar fits perfect no issues
  6. Jul 21, 2017 at 6:27 PM
    CJ21
    CJ21 CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
    7" BDS Lift.
