6 inch Readylift with TRD skid plate?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by JC-TRD-TX, Jan 20, 2020.
  1. Jan 20, 2020 at 2:45 PM
    JC-TRD-TX
    JC-TRD-TX [OP] New Member
    2020 Toyota Tundra Army Green
    6 inch ready lift Kit Ranch hand grille guard
    After hours of research and threads I still cannot find a clear answer so I need y’alls help. Is it anyway possible to INSTALL THE OEM TRD SKID PLATE WITH A 6INCH READYLIFT??? Any info, links, or instructions would be a big help. Thanks In advance.
  2. Jan 20, 2020 at 3:13 PM
    so_juanderful
    so_juanderful New Member
    Honolulu, HI
    2017 Cement Tundra TRD Pro
    Did you try contact Readylift?
  3. Jan 21, 2020 at 8:36 AM
    19TRDPRO_FL
    19TRDPRO_FL New Member
    Paul
    Parkland, FL
    2019 Tundra TRD Pro
    Audio: Pioneer 8200NEX Infinity Kappa complete speaker package 4 Channel Kenwood amp 5 Channel Kenwood amp 10 inch JL Audio W1 shallow mount sub X 2 Readylift Pro Plus 4in lift (6 total) 22x12 Fuel Sledge wheels 35x12.5R22 Nitto Ridge Grapplers LED bar in hood scoop LineX step rails
    I researched this for a month and had a custom truck shop try, it never worked. I have a 2019 Pro, with the ready lift pro plus 4in. I ended up selling my skid plate for $300.
  4. Jan 21, 2020 at 2:12 PM
    808skycm
    808skycm New Member
    2015 Silver Sky Crewmax 4x4
    On their site at the very bottom someone asked about this and they said it won’t fit on the 6in because of something with the crossmember. 4in has a part number for the spacer but I guess that’s the max they do.
  5. Jan 24, 2020 at 7:02 AM
    No Limit
    No Limit New Member
    Alberta
    2020 Tundra TRD PRO 4” Readylift
    2020 PRO with 4” Readylift I also bought the Readylift TRD PRO Skid Plate Drop Kit...tried to install but it didn’t work, read the fine print and that kit is for 2” lift only...sold my Skid Plate as well.
    I like the look without it anyway.
  6. Jan 24, 2020 at 1:47 PM
    ackthresher
    ackthresher New Member
    Jamie
    2017 cement crew max tundra pro
    Do you have pics with the lift?thanks
  7. Jan 24, 2020 at 2:19 PM
    No Limit
    No Limit New Member
    Alberta
    Front view no Skid Plate
    dharo and JC-TRD-TX[OP] like this.
  8. Jan 24, 2020 at 2:34 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Has anyone asked RCI about this issue, maybe they have a aftermarket skid plate that works.
  9. Jan 24, 2020 at 5:28 PM
    ackthresher
    Jamie
    Man that looks good!!thanks
