6 inch ProComp Lift Stage I Question
Discussion in 'Wheels & Tires' started by TUNDRAZX1400, Aug 8, 2017.
  1. Aug 8, 2017 at 3:54 PM
    TUNDRAZX1400
    TUNDRAZX1400 [OP] New Member
    2013 Gun Metal Gray Texas Edition Tundra
    Toneau BakFlip 7' Bed Cover Yakima Bike Rack
    AS OLD FRANKY SINATRA WOULD SAY " I DID IT MY WAY" THIS IS The Build I was looking for Next Im going with LED Spyder Head Lights !!!
    My 2016 Crew max lifted less than 3 days ago. New to driving a lifted truck noticing Rubbing while trying to park vehicle. Is this Normal with any lift?
    6 inch Pro Comp Stage I
    35 inch 12.5 Toyo RT
    20X10 Fuel Assaults
    Otaku4life69 and Jsena like this.
  2. Aug 8, 2017 at 4:00 PM
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    What's the backspacing on the wheels. Probably rubbing against the cab mount.
    Personal opinion now, ditch the ProComp and get something more useable, like the ToyTech Boss kit or Kings in all 4 corners and upper control arms.
  3. Aug 8, 2017 at 4:05 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Did they mention cutting anything? Just had mine done 3 weeks ago.. they had to CMC mine then it only rubbed in reverse so I saw where it was rubbing from the front end and the plastic lining up front.. just trimmed it a little ans its over now.tthere's some stuff on it in my build page and others showing how it's done .. good luck
    Law323 likes this.
  4. Aug 8, 2017 at 4:05 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Pictures of the truck????
    AxelsHumanDad likes this.
  5. Aug 8, 2017 at 4:52 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Probably need a CMC
  6. Aug 8, 2017 at 4:55 PM
  7. Aug 8, 2017 at 5:03 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    For starters I would take it back to the shop that did the install. They should have cycled the suspension and road tested. Now if you did the install, another story. Just have a buddy take a look while you turn the wheels lock to lock. You should be able to see where it's rubbing . Good luck and post some pics. Almost all rubbing issues come down to wheel offset and not lift.
  8. Aug 8, 2017 at 5:15 PM
    Tundra_mike89
    Tundra_mike89 New Member
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Toytec boss coilovers Toytec shackles Total chaos uca's Method wheels Nitto ridge grapplers
    In all honesty your wheel and tire selection was poorly chosen. I hope I'm not coming off as an a-hole but you might need to rethink the setup. Cmc=no Bueno IMO
  9. Aug 8, 2017 at 5:25 PM
    Sefferston
    Seth
    ERMERGERD TOYOTA
    Why do you say this?
  10. Aug 8, 2017 at 5:25 PM
    CM-LENNY
    San Diego, CA
    I wouldn't stress to much, as it's probably a fairly easy fix. Even a minor CMC (cab mount cut ) is a minor fix for someone with the right tools. I am sure you did your research on lift, wheels and tires prior to your install, and if that's the look you're after, don't let anyone steer you away. Just a little research and you'll have this resolved before you know it !
    TUNDRAZX1400[OP] likes this.
  11. Aug 8, 2017 at 5:27 PM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    I just don't like cutting into the frame. But I'm a weird o
    CM-LENNY likes this.
  12. Aug 8, 2017 at 5:28 PM
    Sefferston
    Seth
    ERMERGERD TOYOTA
    That's why you weld a piece back on :anonymous:
    Law323 and CM-LENNY like this.
  13. Aug 8, 2017 at 5:29 PM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    I don't know how to weld and that's another reason I don't like cmc lol.
    Law323 likes this.
  14. Aug 8, 2017 at 5:30 PM
    Sefferston
    Seth
    ERMERGERD TOYOTA
    So get a shop to do it haha. There are plenty of people around the country more than willing to do it for you.
  15. Aug 8, 2017 at 5:31 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    That's not true at all.. he knew what he wanted by buying the wheels and tires that he did. That's exactly what he wanted and why he purchased it. Maybe he didn't know about rubbin issues or even what CMC meant, but that doesn't mean he made a poor choice at all.. CMC is not big deal at all and when done, you can't even tell it's been done.. OP don't let any negative feedback discourage you. I'm sure the truck looks badass and it was just something you didn't know about and that's no big deal.. I had my lady sit in my truck and lock it all the way right and left in forward and revers so I could see where it was rubbing. Then took care of it.. you wanted your truck to look a certain way "lifted" just like 50% of the people in here. So finish it up and let's see some pics :curls::burnrubber:
  16. Aug 8, 2017 at 5:33 PM
    Sefferston
    Seth
    ERMERGERD TOYOTA
    50% seems a little low. Everyone wants their own vehicle the way they want it.
    CM-LENNY, Jsena and Law323 like this.
  17. Aug 8, 2017 at 5:34 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    You beat me to it!
    I'd say about 80-90% on this forum and about 70% outside this forum. The rest don't count LOL
  18. Aug 8, 2017 at 5:35 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Lifted ** lol than have done the CMC
    Law323 likes this.
  19. Aug 8, 2017 at 5:36 PM
    Sefferston
    Seth
    ERMERGERD TOYOTA
    #35sandlongtravel #nuffsaid
    Law323 and Jsena like this.
  20. Aug 8, 2017 at 6:05 PM
    TUNDRAZX1400
  21. Aug 8, 2017 at 6:10 PM
    TUNDRAZX1400
    Law323 and Jsena[QUOTED] like this.
  22. Aug 8, 2017 at 6:14 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Makes more sense that way! LOL
    Jsena[QUOTED] likes this.
  23. Aug 8, 2017 at 6:14 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Looks Sickkk Bro.. try to take some pictures of the front end where the wheels is and the back of the front wheel, on both front sides.. maybe we can see how close it is and know exactly ..
  24. Aug 8, 2017 at 6:15 PM
    TUNDRAZX1400
    ok will do out on oil rig right now will be back in a week
  25. Aug 8, 2017 at 6:18 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    That part that stuck out was hitting my tire at full lock so I just drilled a hole and moved the screw up, and then cut the remain off so it wouldn't hit, the last pic is the back of the front tire that's had the CMC done.. they cut it off, put a flat metal pieces back and paint it to match. It's no big deal bro..
    Last picture is what it was before the cut then the others were after I moved the bolt up and cut rest off
    Les7311 and Law323 like this.
  26. Aug 8, 2017 at 6:21 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Damnnnn lol, cool.. Hv fun
  27. Aug 8, 2017 at 6:21 PM
    TUNDRAZX1400
    oh shit that's exactly how mine looks .. Man you nailed it bro!!! Cheers Heineken On me!!!!
  28. Aug 8, 2017 at 6:23 PM
    JAMES
    JAMES COLORADO TUNDRA
    2016 Colorado Tundra Crew Max MGM
    6" PC Stage II Coil Over 37x12.50x20 Toyo RT 20" Fuel Recoil Wheels N-Fab black Step Bars Splash 5% Window Tinting Clear Mask Protection Premium leather interior with 2-front Heat/Cool seats Viper 5806v Alarm w/ remote start Garmin 2589 Garmin Dash Cam Dual Flo-Pro 3.5 18" Glass Packs Black Chrome exhaust tips Bakflip Bed Cover Weather Tech Floor Mats Bushwacker Pocket style with matching paint TRD Pro Grill Tesla 12.1'' Head Unit Oh Shit handle on Drivers Side Under seating Storage 4.88 Gears NSV LED Light bar Upgraded Sound system with JL Audio Speakers and Sub
    I have a 6 inch pro comp stage ll with 37x12.5 20" Just had to do some trimming on the front plastic cover. Nothing rubs on the frame...... IMG_2152.jpg
  29. Aug 8, 2017 at 6:26 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Looks mean!!!! Nice
  30. Aug 8, 2017 at 6:27 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Not sure exactly but 2 big time shops here in Vegas including 4 wheel parts told me that the pro comp 6 inch lift is really a 7 inch lift... ¯\_(ツ)_/¯ anyone else ever heard that?
