6 in lift and Alignment
Discussion in 'Suspension' started by jptshadow, May 16, 2018.
  1. May 16, 2018 at 7:55 PM
    jptshadow
    jptshadow [OP] New Member
    So they say once you pass 3 inch lift, alignment seems to go off easily. True or false? Also heard people with 7in with F150 w/o issues. Any advice?
  2. May 16, 2018 at 8:05 PM
    Bought my truck used, it came lifted with a Rough Country 6" kit, went to the dealership ran the vin# the dealership sent the truck to get lifted, I'm on stock UCAs, I'm still having small issues with alignment, I'm buying the SPC UCAs soon
  3. May 16, 2018 at 8:07 PM
    jptshadow
    ...... UCA ?
  4. May 16, 2018 at 8:09 PM
    Upper Control Arm
  5. May 16, 2018 at 8:12 PM
    jptshadow
    Oh I see. So if I buy the whole kit from RoughCountry. I need to buy another UCA?
  6. May 16, 2018 at 8:18 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I have a Procomp stage 1, 6 inch lift. Steering wheel is perfectly straight. Doesn't pull to the left or right. And no uneven tire wear. Hope that helps.
  7. May 16, 2018 at 8:43 PM
    Stay away from RC or a spacer lift kit
    mudslinger79 likes this.
  8. May 16, 2018 at 8:46 PM
    I believe anything 6" or higher, the rear crossmember gets cut, and once cut ther no turing back, I have an older model kit so technically I can take this kit off, I'd like to go 4-4.5" kit
  9. May 16, 2018 at 9:01 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I’m lifted 7 inches and alignment is good. Doesn’t pull either way.. straight as an arrow
    Black Wolf, jeremyd and GNTundra like this.
  10. May 17, 2018 at 7:01 AM
    jptshadow
    What brand is recommended besides RoughCountry?
  11. May 17, 2018 at 7:04 AM
    You have...
    Toytec Boss Kit
    Ready lift
    BDS
    Pro Comp
    Bullet Proof
    jptshadow[QUOTED][OP] likes this.
  12. May 17, 2018 at 7:06 AM
    Fabtec
    Revtech
    Skyjacker
    Superlift
  13. May 17, 2018 at 7:07 AM
    Anytime you dissemble the front end components such as an UCA, I would recommend an alignment.
    040Tundra and Jsena like this.
  14. May 17, 2018 at 7:08 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I purchased specifically the Procomp Lift due to the 50000 mile warranty. My truck was new when I had it installed.
  15. May 17, 2018 at 7:08 AM
    Which I'm doing now.....
    T-Rex266[QUOTED] likes this.
  16. May 17, 2018 at 7:24 AM
    I'm on stock UCA, I'm getting info on here that would help my numbers get better and spoke with SPC and they said since I'm lifted there product can help out to get me lined up
  17. May 17, 2018 at 8:14 AM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    Why, What does rough country do differently that the other bracket lift companies? They actually offer the highest ground clearance of any 6" equivalent lift on the market.
  18. May 17, 2018 at 9:27 AM
    I have a 6" RC and have zero complaints rides good handles good. My tires wear even I like a lifted truck but not a serious off roader so works great for me. I am sure if you do all lot of off reading there are better options but I drive on the road most of the time and through a field to hunt do just depends on what you are doing with it I suppose.
  19. May 17, 2018 at 1:58 PM
    jptshadow
    I am lifting just in case I have to get through some deep water during storm. Occasional non paved wild field roads. Thaz about it.
  20. May 17, 2018 at 2:06 PM
    Think you be alright with a 4-4.5" kit, but really up to you
  21. May 17, 2018 at 2:20 PM
    jptshadow
    Was thinking abt that too. More practical in a sense for loading goods and all.
  22. May 17, 2018 at 2:35 PM
    Yeah cause I have a hard time getting into the back of mine, I need that AMP Research bed step
  23. May 18, 2018 at 1:49 PM
    dongkatsu
    dongkatsu New Member
    Dong
    2017 Black Tundra Platinum
    7" bds gone due to issues and switched out the kit to Readylift 6" and up to 7"
    go readylift. out of all drop bracket lift they have the least issue. next is pro comp.
  24. May 19, 2018 at 8:31 PM
    250rdave
    250rdave like I told the guy on ABC DANGER IS MY BUSINESS
    David
    surprise az
    2014 blue trd dbl cab
    Borla cat back Airraid cai raptor grill pro comp at sport
    I just installed a 6" procomp lift kit with king c/o for a pro comp 6" lift and jba ucas I took my tuck to 4wp to have them align the truck and was told the ucas were not allowing the truck alignment to be brought in to spec. Any body else running jba ucas with a p/c 6" lift
  25. May 19, 2018 at 8:39 PM
    Page 7, last post, but don't say what ther lift is
    https://www.tundras.com/posts/587611/
