6 gang switch panel who has it?
Discussion in 'Lighting' started by xtyfighterx, Mar 21, 2020.
  1. Mar 21, 2020 at 6:57 AM
    xtyfighterx
    xtyfighterx [OP] New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Found this guy on Amazon anyone have it? Curious where you mounted it and how it’s holding up
    itsuperhero, Rica25 and iHacker like this.
  2. Mar 21, 2020 at 7:04 AM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    I've seen this Amazon switch box on YouTube a few times with people doing reviews. I'd say for the install the relay box could be installed on the fuse panel cover in the engine bay and then put the control head wherever works best for you. I know this is common for SPOD's and Switch-Pro installs. When I did my switch pro install I did it the same way and the buttons are just behind the shifter.
    Rica25 likes this.
  3. Mar 21, 2020 at 2:21 PM
    xtyfighterx
    Ty
    North Idaho
    That’s where I was thinking that little cut out behind the shifter. I’d have to drill a hole to run the cord through the column.
    Rica25 likes this.
  4. Mar 21, 2020 at 2:24 PM
    Rica25
    Ricardo
    Tulare
    I have it
  5. Mar 21, 2020 at 2:26 PM
    Rica25
    Ricardo
    Tulare
    Mounted on top of the fuse box with 5 of the 6 switches being used inside the cab I mounted to the left side of steering wheel tight below the side view mirror control. I installed it there so the led lights of the control panel to not bug me while driving did not want the light in my eye sight
    SIXSEVENONE likes this.
  6. Mar 21, 2020 at 2:39 PM
    xtyfighterx
    Ty
    North Idaho
    Cool man how’s it working out for you?
    Rica25[QUOTED] likes this.
  7. Mar 21, 2020 at 2:49 PM
    Rica25
    Ricardo
    Tulare
    Only had it for about 2 months and so far so good
  8. Mar 21, 2020 at 2:51 PM
    xtyfighterx
    Ty
    North Idaho
    Pics of your mounting in the cab?
  9. Mar 21, 2020 at 2:52 PM
    Rica25
    Ricardo
    Tulare
    Dont have any right now. I'm at work but its left side right below the controls for the driver side mirror control right when it angles down
    xtyfighterx[OP] likes this.
  10. Mar 21, 2020 at 2:54 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I looked at that one too but for another 100 you can get the trigger 4 plus which is what i went with.
    Neither are the quality of switch pros but I ain’t trying to pay $600. I’ll save that for the lights themselves lol
    Rica25 likes this.
  11. Mar 21, 2020 at 2:55 PM
    Rica25
    Ricardo
    Tulare
  12. Mar 21, 2020 at 3:05 PM
    xtyfighterx
    Ty
    North Idaho
    Link to you the one you want? Same I don’t need anything crazy just wanna clean up my wiring
    Rica25 likes this.
  13. Mar 21, 2020 at 3:10 PM
    xtyfighterx
    Ty
    North Idaho
    I like the flush buttons not big on rockers I found another one for $120 but it’s 8 gang box I don’t need that much looks a little nicer
    Rica25 likes this.
  14. Mar 21, 2020 at 3:16 PM
    xtyfighterx
    Ty
    North Idaho
  15. Mar 21, 2020 at 3:53 PM
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    CaptJim1794 likes this.
  16. Mar 21, 2020 at 4:05 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    I bought the relay/fuse box a couple of years ago before the whole kit was available and the quality was so bad it wouldn't hold fuses. They would just pop out of the terminal a few seconds after I put them in.
    I spent a ton of time planning out the wiring and getting it wired up, but I ended up having the buy something else because the fuse terminals were essentially non-functional.
    This may be a different company, but that relay box is the same. It was useless.
    Rica25 likes this.
  17. Mar 25, 2020 at 8:37 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    I got my Relay/ Fuse box off Amazon and have been extremely happy with it.
  18. Mar 25, 2020 at 3:52 PM
    careyrob
    Carey
    Massachusetts
  19. Mar 25, 2020 at 3:56 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    You have a link?
  20. Mar 25, 2020 at 4:05 PM
    careyrob
    Carey
    Massachusetts
    Don't do it! That relay/fuse box is garbage!
    I bought it and it wouldn't allow the fuses to seat well enough to keep them from popping out. It was a manufacturing issue. Very poor plastic mold quality.
  21. Mar 25, 2020 at 4:06 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    10-4 on that! Thanks!
  22. Mar 25, 2020 at 4:08 PM
    xtyfighterx
    Ty
    North Idaho
    Just search 6 gang switch panel should come up for you. I think I’m going with the 8 gang box I posted after that one
  23. Mar 25, 2020 at 4:08 PM
    careyrob
    Carey
    Massachusetts
    :thumbsup:
    Rica25 likes this.
  24. May 6, 2020 at 6:46 AM
    Marshwalker
    Marshwalker New Member
    Z
    Do you have to have a negative panel to add switches to?
  25. May 6, 2020 at 6:50 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    I have this in my 4runner - my only complaint is that it doesn't have ground terminals and each device needs to be individually grounded.
  26. Jun 17, 2020 at 5:09 PM
    TemujinNomad
    TemujinNomad New Member
    Which one did you end up getting? How’s it working out so far?
  27. Jun 17, 2020 at 6:17 PM
    xtyfighterx
    Ty
    North Idaho
    Nothing yet truck mods on hold working on getting the house landscaped and all finished. I’ll update once I do buy tho
    Rica25 likes this.
  28. Jun 18, 2020 at 6:05 AM
    Backslider
    Tooele, UT
    I have a very similar setup on my 4runner - 2 years in with zero issues.
    Rica25 likes this.
