5th wheel towing ?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by rockmup, Nov 4, 2019.
  1. Nov 4, 2019 at 9:13 AM
    rockmup
    rockmup [OP] New Member
    Todd
    Greenwell Springs LA.
    Anyone in here do it ? Ours weighs 8500 dry. Considering a 2020 1794, I understand about pin weights etc, looks like I'd need airbags, maybe a rear sway bar. Other than that it pencils out good.
  2. Nov 4, 2019 at 10:22 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Naw. Get a diesel.
    You'll be way over on weight.
    YotaMan and FrankW like this.
  3. Nov 17, 2019 at 6:17 PM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    2018 White Tundra Limited DC 4x4 TRD
    BFG KO2s, TRD Rear Sway Bar, Firestone RideRite Air Bags, B&W Gooseneck Hitch, Trail Ridge Extendable Towing Mirrors
    From my quick search, the max payload for the most capable 2020 Tundra is 1,730lbs. 5th wheel trailer pin weights are usually around 20% of their dry weight. Your pin weight is approximately 1,700lbs. Remember, anything you add to the trailer's dry weight, 20% of that weight transfers to the truck plus passengers and cargo in the truck.
  4. Nov 17, 2019 at 6:20 PM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    Where there's a will, there's a way ;)
    KMG, Seyc and 2manytoys like this.
