5th Wheel Towing on New 2022 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by RV Tundra, Dec 5, 2021.
  1. Dec 5, 2021 at 9:56 AM
    RV Tundra
    RV Tundra [OP] New Member
    Bernard Wayne
    Okotoks Alberta
    Tunrda SR5 (2018) Colour Inferno
    TRD Rear Sway Bar, TRD Intake, Tow Mirrors, Interior Floor Light, Drivers Side Grab Bar, Baja Fog Lights, TRD Front Sway Bar, TRD Exhaust, Air Bags with compressor and remote. Custom Leather Interior, Front Runner Roof Rack, Wilson Antenna installed.
    Does anyone know if you can install a 5th wheel hitch on the new 2022 Tundra with its new Box construction??
    HavasuRose and sask3m like this.
  2. Dec 5, 2021 at 9:57 AM
    cain0725
    cain0725 New Member
    im sure i can ,
    AJGallo41 likes this.
  3. Dec 5, 2021 at 10:02 AM
    I'm sure you can, but the payload is still going to be too low for it. Unless you are going for a super light weight (read small) 5th wheel like the Escape 5.0 https://escapetrailer.com/the-5-0-escape/ then a 5th wheel has too much tongue/pin weight for a half ton truck. You need to move up to a 3/4 or 1 ton.
  4. Dec 5, 2021 at 3:19 PM
    cain0725
    cain0725 New Member
  5. Dec 5, 2021 at 8:00 PM
    RJN55
    RJN55 New Member
    2018 Tundra LIMITED DC (Flares, Rear Sway Bars, Timbrens, B&W Gooseneck Hitch, Running Boards, Visors, 18 inch rims with 10 ply Michelin AT/2's, Bed Lights, Tow Mirrors
    Tow weights in the 2022 owners manual seem to be the same as my 2007 and 2018 Tundras. (8300 to 11,400 lbs). Suggested king pin weight in manual is, to quote, The gross trailer weight should be distributed so that the kingpin weight is 14% to 16%. (Kingpin weight/Gross trailer weight x 100 = 14% to 16%). Can't answer who has a 5th wheel to fit the 2022 yet.
  6. Dec 5, 2021 at 8:07 PM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    2nd gen was rated to tow “upto 10,000#”
  7. Dec 6, 2021 at 2:09 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    It's all about payload. Most half ton trucks don't have enough payload once loaded down with people, pets,, accessories camping gear, trailer hitch and other whatnot. Realistically fifth wheel campers should be towed with 3/4 or 1 ton trucks.
  8. Dec 6, 2021 at 5:22 AM
    Indeed. The Escape 5.0 is the only half ton friendly 5th wheel I've seen, but most people that want a 5th wheel want something 25+ feet long with multiple slide outs. That's all well and good, but it's too much for light duty trucks, and half tons are light duty. You need to move a couch or a fridge? Half ton will do it easy. Tow your motorcycles or a couple quads? Sure. Getting a travel trailer the size of a small house or anything that is 5th wheel? It's time to get a Heavy Duty truck 'cause your half ton isn't made for that.
    Dsptundra and Cpl_Punishment like this.
  9. Dec 6, 2021 at 6:26 AM
    Synergy
    Synergy New Member
    Jamie
    I’m looking to upgrade my 2012 Tacoma to a 2022 Tundra. My family tows horses and my taco does ok with a 2 horse bumper pull but we need to pull 3 horses and a gooseneck is more suited for that. Anyone have thoughts on the new Tundra pulling a gooseneck? I’m looking to get a featherlight trailer and fully loaded with horses and tack if estimate it would be around 10,000 lbs well below the 12,000 rating. I’ve also stretched my taco’s rating well over the 6,800 lbs on the sticker so I feel like Toyota is overly conservative with this rating. Direct experience pulling a gooseneck with a Tundra would be helpful. Thanks.
    HavasuRose likes this.
  10. Dec 6, 2021 at 6:49 AM
    As stated previously, tow rating is not what you need to look at. You need to look at the payload rating and the tongue/pin weight of the trailer. Also, those advertised tow ratings are always for 2WD no option trucks. If you don't have a barebones truck you don't have that max rating.
    Lets crunch some basic numbers here. 10,000 pound trailer and let's say you have a dead on 10% pin weight of 1,000 pounds as a best case scenario. If that Tundra has a payload of 1,500 pounds then you have 500 pounds remaining to cover the hitch you have installed to pull the trailer, any upgrades or mods to the truck including wheels or tires, any and all gear, plus your passengers. If you manage it all properly you might be able to pull this off.
    Now what if you have a 12.5% pin weight of 1,250 pound? Then you only have 250 pounds for the hitch, mods, gear, and passengers. Much less likely to work at this point.
    TLDR: If your tongue/pin weight is going to be over 600-800 pounds you can really easily wind up over your payload ratings. Best case for this will be increased wear and tear, higher maintenance costs, and a less than stellar towing experience. Worst case? Well, you can lose control of your vehicle and deal with all the possible outcomes.
  11. Dec 6, 2021 at 7:43 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    The OP's question was about installing a 5th wheel hitch not whether or not he should be towing one.
    Leo's first, eebozz, Hbjeff and 4 others like this.
  12. Dec 6, 2021 at 7:45 AM
    Yup, and that was already addressed.
  13. Dec 6, 2021 at 7:46 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    "I'm sure you can" wasn't really a definitive answer.
    damnfingers and HavasuRose like this.
  14. Dec 6, 2021 at 7:57 AM
    Correct. The more complete answer followed that.
  15. Dec 6, 2021 at 8:16 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Your complete answer about the size of trailer he could pull wasn't what he asked.
    damnfingers likes this.
  16. Dec 6, 2021 at 8:27 AM
    Let me put it into an equivalent setting.
    OP asks "Can I stab myself in the leg?"
    Options for answering:
    1. No. You can't. (This would be a lie.)
    2. Yes. You can. (This is true, but lacks information that the OP might want to have before making the decision.)
    3. I'm sure you can, but it's gonna be a bad op. I would advise against it. (Answers the question, but also provides additional info so the OP can make an informed decision.)
    In an attempt to be a helpful member of the community, and society at large, I opted for number 3.
  17. Dec 6, 2021 at 8:33 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Thanks dad.
  18. Dec 6, 2021 at 8:41 AM
    No, no, no. @War Machine is the one with illegitimate Canadian offspring. You've got me confused with somebody else. :p
  19. Dec 6, 2021 at 8:58 AM
    Toyota1234
    Jack
    Your truck will be closer to 11k towing. You should get a bigger truck.
    plumber802, Cpl_Punishment and 1UP like this.
  20. Dec 6, 2021 at 9:10 AM
    TundyMcTunra
    TundyMcTunra Irrational people are not often convinced by facts
    Lost in the PNW
    2010 Tundra Limited Crew Max 4x4, 2018 Tacoma Inferno TRDORDCSB, 2019 Rav4 Lunar Rock, 1991 4Runner Crawler. Ivan Stewart Edition
    Don't do it
    plumber802 and 1UP like this.
  21. Dec 8, 2021 at 8:12 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    There are other options on 5th wheels other than Escapes. Winnebago makes a nice 1/2 ton towable 5th wheel with a pin weight of just over 800lbs.
    https://www.winnebago.com/models/product/minnie-plus?GroupID=GROUP277
    plumber802 and GODZILLA[QUOTED] like this.
  22. Dec 8, 2021 at 8:31 PM
    guppydriver
    guppydriver New Member
    2020 SR5 TRD
    I don't think I've ever seen a 1/2 ton with a fifth whell hitch...
    I agree its HD truck territory. Best news though, youll save some money over a new Tundra :)
    Order a f250 gasser with the Godzilla and never worry about payload again. 3% under invoice plus any rebates. I thought about it, but can't handle daily driving a SD/HD truck.
  23. Dec 8, 2021 at 8:42 PM
    pickupjason
    pickupjason New Member
    2019 Silver Crewmax TRD offroad 4x4
    Could you let me know which dealer is offering the deal?
  24. Dec 8, 2021 at 8:58 PM
  25. Dec 8, 2021 at 9:57 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The 800lbs pin weight is for the dry weight. I would think around 1K depending how you load so you should be able to stay under payload if you load it conservatively. There really isn't all that many option when it comes to a light 5th wheel.
    GODZILLA[QUOTED] likes this.
  26. Dec 8, 2021 at 10:38 PM
    Yup. That's why the general rule of 5th wheels being beyond half ton capabilities is true 99% of the time.
    Cpl_Punishment likes this.
  27. Dec 9, 2021 at 5:40 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Some are willing to go right up to the max payload for the pin weight and even a couple hundred over and I can completely understand why. If you have ever pulled a 5th wheel compared to a bumper pull it's a night a day difference. It's odd that people have no issue with towing a 800lbs tongue weight trailer that's 28' long but if someone hooks up a 1200lbs pin weight 5th wheel at 25' long you are now endangering everyone and yourself on the road.
    blenton and Nm6300'asl like this.
  28. Dec 9, 2021 at 10:27 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Half ton trucks are not designed to pull a 5th wheel. Use the right tool for the job and that means HD 2500 or 2500 series truck.
    unless it was something like this
    GODZILLA, Oey12 and Cpl_Punishment like this.
  29. Dec 9, 2021 at 10:32 AM
    I've pulled tons of stuff. Pulled trailers for a living for a time. That's part of why I lean to the conservative side of towing combinations. I've towed things at (and probably over) limits and it's a miserable experience.
    The driver is a huge factor in the equation. Somebody just starting to tow that wants to tow at their weight limits and wants to do it at 80 mph is a scary thing. At the same time, a very experienced driver I would have no issue with driving the same vehicle. The experienced driver is going to be more aware, keep better follow distances, and is way less concerned with the speed limit than they are getting to their destination safely.
  30. Dec 9, 2021 at 10:50 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I think one big thing is that the experienced driver knows when they need to slow down and the inexperienced driver may not.
    GODZILLA[QUOTED] and Oey12 like this.
