5th wheel hitch
Discussion in '3rd Gen Tundras (2022+)' started by leafs1967, May 13, 2025 at 5:48 PM.
  1. May 13, 2025 at 5:48 PM
    leafs1967
    leafs1967 [OP] New Member
    Yesterday
    Tony
    2024 Tundra trd
    Can anyone tell me what they are using for a 5th wheel hitch on a 2024 tundra trd crewcab 6.5 box. lm in Canada and having trouble finding anything.
  2. May 13, 2025 at 6:01 PM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    5th wheel hitches aren’t advised for half ton pickup trucks.. lol
    Breathing Borla and GODZILLA like this.
  3. May 13, 2025 at 7:43 PM
    blenton
    blenton New Member
    I believe the best way to use a 5th wheel in the 3rd gens is with a gooseneck hitch and gooseneck to 5er adapter. I don't know how well the composite bed would hold up to traditional 5th wheel hitch; I know that Decked won't (or didn't) allow you to mount their bed slide in the composite bed, though I'm sure there are workarounds for that such as sammiching the slide mounts with steel plate.
    B&W makes a 3rd gen setup utilizing their turnover ball gooseneck hitch and companion 5th wheel adapter. There are several other manufactures that produce goosneck to 5th wheel adapters that work well. Andersen makes a lightweight unit, for example. A friend of mine uses a gooseneck to 5er adapter in his duramax and it works well for him.
    Gooseneck hitch:
    https://www.etrailer.com/Gooseneck-Hitch/B-and-W/BW96FR.html
    5er kit with gooseneck hitch:
    https://www.etrailer.com/5th-Wheel-Hitch/Toyota/Tundra/2022/BW45XR.html?VehicleID=20226005818
    I don't know what is available to you in the great white north.
  4. May 14, 2025 at 4:56 PM
    leafs1967
    Yesterday
    Tony
    2024 Tundra trd
    Thanks for the information. I think I'll end up going that route.
  5. May 14, 2025 at 5:05 PM
    What trailer are you planning to pull?
    Look up it's pin weight and then look in the door jamb of your tundra at your payload. Odds are you'll be over payload with any 5th wheel and probably even gooseneck.
