5speed or 6speed trans. ?
Discussion in '2nd Gen Tundras (2007-2013)' started by Kendra4x2, Oct 12, 2023.
  1. Oct 12, 2023 at 11:37 AM
    Kendra4x2
    Kendra4x2 [OP] New Member
    2007 Dbl. Cab SR5 5.7L lng bd
    Can I find out if I have a 5spd or 6spd transmission by my VIN? 2007 ,SR5 5.7L
  2. Oct 12, 2023 at 11:42 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Put your truck in manual shift mode. Bump the shifter forward and see what it says on your dash readout. It will say 6
  3. Oct 13, 2023 at 8:48 AM
    Kendra4x2
    I can't find anything about put in the truck in manual shift mode.
    My two attempts to follow your instructions showed a "4" in the little window on the dash.
    So I'm thinking I either didn't do it right or I'll continue to search further on the subject. Thanks for your input.
  4. Oct 13, 2023 at 8:50 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    5.7 comes only with AB60E/F, which is 6 speed.
  5. Oct 13, 2023 at 8:51 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    if you push the gear selector up 2 times or hold it, it will show you the yellow brick road brother. They're 6spd transmissions.
