5mm spacers? First gen Tundra
Discussion in 'Wheels & Tires' started by CaliTundra916, Feb 18, 2024.
  1. Feb 18, 2024 at 9:18 PM
    CaliTundra916
    CaliTundra916 [OP] New Member
    2006 Tundra DC
    I’m looking to add 5mm wheel spacers but they don’t have a hub bore ring. Is the hub ring even necessary for this size spacer? I mean is the bore on the stock hub piece long enough to use a spacer this size and still have enough bore width available for the wheel? Hopefully I didn’t garble my explanation:|
  2. Feb 19, 2024 at 4:05 AM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I just tested a 1/4" spacer yesterday, which is just over 6 mm, on my 06 2WD DC and no, there was not enough.
    CaliTundra916[OP] likes this.
  3. Feb 19, 2024 at 10:49 PM
    CaliTundra916
    2006 Tundra DC
    Thanks @Weagle . I appreciate the speed of the reply and your time sir . I figured it was a long shot the bore was long enough. Guess I’ll need to go with the KSP 1” hubcentric spacers or similar if/when I decide on extending the stance a bit.
