Occupant airbag sensor
Discussion in '2nd Gen Tundras (2007-2013)' started by Punisher17, Dec 21, 2019.
  1. Dec 21, 2019 at 8:59 PM
    Punisher17
    Punisher17 [OP] New Member
    I haven't found much info on this. The reason I am posting here is because I need help. My passenger side airbag light will say off even when someone 170lbs is sitting there also confirmed that the seatbelt sensor doesnt work either when the seatbelt is unbuckled
  2. Dec 23, 2019 at 5:12 PM
    Punisher17
    It did not fix the problem. I also just unplugged the seat belt latch plug underneath the seat to just see what would happen and when I do that the seat belt light will come on and flash while the airbag off light is still on while sitting in the seat with or without the seat belt on
  3. Dec 27, 2019 at 6:35 PM
    Punisher17
    If anyone has this problem in the future I have resolved it. I ordered a new seat belt latch for the passenger side for $45 OEM Toyota part uninstalled the seat and installed the new seat belt latch reinstalled everything now the airbag ON light comes on when someone is sitting there and the seat belt light is also working. Going to return the Occupant Detection Sensor and this fix will have cost me only $45 :thumbsup:
    1lowlife, TheBeast, Les7311 and 2 others like this.
  4. Feb 1, 2020 at 8:21 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Bump
    Vince likes this.
  5. Mar 18, 2020 at 7:56 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    Where did you find the replacement seatbelt I have the same issue
  6. Mar 19, 2020 at 8:45 AM
    Les7311
    The passenger side latch needed replacement Stealership was $55 and a 30 minutes DIY
  7. Mar 21, 2020 at 6:09 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Nice, my driver side has a pending code for this too...
  8. Feb 3, 2021 at 2:43 PM
    jag-engr
    jag-engr New Member
    2010 Tundra CM 4WD 5.7 FFV, 1794 package, Sand color
    Does anyone have a tutorial for replacing the seat belt?
    It looks like I need to pull the whole seat to change the belt. Is there any concern about the airbag system? I know that if you do anything with it, you're supposed to disconnect the battery and let any residual charge dissipate.
  9. Feb 3, 2021 at 5:10 PM
    blackdemon_tt
    For space maybe, not necessarily.. you will have to pull the trim on the B pilar
    https://youtu.be/EM77KBVgaow
  10. Feb 3, 2021 at 6:16 PM
    Vince
    Vince New Member
    Vincent
    I discontented the battery and unplug all the sensors under the seat and replaced my seat belt buckle. It did not fix my problem of the air bag light or the pressure sensor
    jag-engr likes this.
  11. Feb 3, 2021 at 10:38 PM
    Punisher17
    The air bag system has a lot of different parts and sensors and supposedly you’d only want to have it serviced by Toyota. I googled a whole bunch of different thing about the Tundra but found something about Camrys that the seat belt buckle has gone bad and caused the air bag light problem on the passenger side which was my exact problem. I first tried the sensor box located under the seat and did not fix the issue then tried the seat belt buckle and it fixed it so I returned the sensor box. I disconnected the battery and I think the sensor under the seat then removed the seat and replaced the buckle. It’s very easy and you can clean when you do it also you don’t even need to take the whole seat out after you remove the 4 bolts. It was a good guess for me too because that buckle was all sticky from something probably spilled in it. Hopefully you can figure it out without too much issue.
  12. Feb 4, 2021 at 3:44 PM
    jag-engr
    jag-engr New Member
    I said that I'm replacing the seat belt, but I'm actually just planning to replace the seat belt receptacle, a.k.a., buckle.
  13. Feb 4, 2021 at 3:47 PM
    jag-engr
    jag-engr New Member
    That's discouraging. I'm hoping that this fixes my issue with the passenger occupancy sensor. The reason that I think that it will is that I do not see a dash light even if neither adult in the front seats is buckled. The chime can be turned off, but not the dash light. That tells me that the previous owner did the seat belt latch mod in which a spring is removed from the buckle. Whether this is the reason that my truck does not register a passenger, though, is purely theory at this point.
  14. Feb 4, 2021 at 3:49 PM
    jag-engr
    jag-engr New Member
    Your experience makes me optimistic!
    Great idea - I didn't think of that. I'll be sure to have some supplies handy.
  15. Feb 5, 2021 at 10:22 AM
    jag-engr
    jag-engr New Member
    Are you getting any warning lights on your dash - seat belts or airbags?
  16. Feb 5, 2021 at 11:55 AM
    Vince
    Vince New Member
    Vincent
    Both. On passanger side
  17. Feb 5, 2021 at 12:01 PM
    jag-engr
    jag-engr New Member
    The problem that Punisher17 and I are having involves absolutely no dash lights or warning codes. As far as the truck is concerned, everything is fine and both seat belts are buckled. This is because the previous owner removed a spring to silence the buzzer. Somehow, though, this modification interferes with the passenger occupancy sensor (or, as I prefer to call it, the POS) and the computer simply will not recognize a passenger in the front seat.
    I'm sorry to hear about your problem. It seems to be more involved and may put you at the mercy of a dealership, which is generally painfully expensive.
  18. Feb 5, 2021 at 12:03 PM
    Vince
    Vince New Member
    Vincent
    I have both passanger seat belt and the passanger air bag stays off all the time it is most likely the 300 dollar pressure sensor in the passanger seat. Whice it has been that way for 150000 miles now.
