5160s wth Dakar Springs
Discussion in 'Suspension' started by Red_Leg, Jan 1, 2019.
  1. Jan 1, 2019 at 4:18 AM
    Red_Leg
    Red_Leg [OP] New Member
    Will
    I want to get a true 3” of lift on all 4 corners. I am looking at doing Dakar springs with Coachbuilder +1 shackles in the rear. I am leaning towards the 5160s but waiting to see the specs on the new falcon shocks.
    I am curios if anyone is running a similar rear setup. How is the ride? Are there any othe digressive tuned shocks you would recommend?
  2. Jan 1, 2019 at 5:00 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I have a AAL and a 1” block currently in the rear with 5100’s. My coachbuilder #2’s just came in yesterday. So I will be removing the block to add the shackles. It will technically be 3” in front and 2.75” in back.
    Maven4x4 and OR18TRD like this.
  3. Jan 1, 2019 at 5:21 AM
    Stewie
    Stewie New Member
    2016 Crew Max
    5160 shocks only appear to support 1.5 to 2 inches of lift. Icon also makes a digressive shock, and you'd have better luck getting the right length shock from them.
    frichco228, Tundyfundy and Maven4x4 like this.
  4. Jan 1, 2019 at 5:34 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    The 5160’s don’t come in extended lengths like the 5100’s do?
  5. Jan 1, 2019 at 5:40 AM
    Stewie
    Stewie New Member
    2016 Crew Max
    According to the Bilstein website, theyre only good for 1.5 inches of lift for the Tundra specific shocks. I could be wrong tho, its happended before.
    OR18TRD likes this.
  6. Jan 1, 2019 at 5:46 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I could be wrong too. Maybe I saw that for the Tacoma
  7. Jan 1, 2019 at 6:28 AM
    Red_Leg
    Will
    I am tracking that the 5160s are only listed for 1” of lift. However, they have the same compressed and extended measurements as the OME shocks. I ran full OME on my last Tundra and I want something “softer” this time.
  8. Jan 1, 2019 at 6:31 AM
    chphilo
    chphilo Tundra addict
    Western PA
    If you are thinking of getting the Dakar springs, you may want to consider the full OME kit (Dakar springs are part of the set). The OME rear shocks are designed to be used for up to 3 inches of lift (last I checked, they had longer travel than Bilstein shocks). Also the front set-up will give you 3+ inches of lift (depending on the coils you choose). I have the medium length (614) coils and got 3 & 1/2 inches of lift in the front.
    AggiePhil, Maven4x4 and OR18TRD like this.
  9. Jan 1, 2019 at 6:40 AM
    Red_Leg
    Will
    I ran the full OME kit on my last Tundra. I am looking for something that will run softer. Unless I go with the Falcons I am looking at the 6112s on the highest setting with a shim.
  10. Jan 1, 2019 at 9:59 AM
    chphilo
    Western PA
    Know what you mean. The ride is rather firm. If price is not a big issue, have you looked into OME BP-51 kit? From what I read, the ride is awesome on this kit.
    OR18TRD likes this.
  11. Jan 1, 2019 at 10:31 AM
    Red_Leg
    Will
    The budget for the coil overs and rear shocks is $1500.
    The bp51 kit does look pretty sweet but twice the budget.
  12. Jan 2, 2019 at 9:09 AM
    Red_Leg
    Will
    I am going to go with the Falcon Sport Tow/Haul kit. I will add shims in the front to get 3 inches. The rear shocks ride 2 inches higher then the competitors. Plus being able to firm up the rear end for towing is a major plus.
    Here are the extended and collapsed measurements. Travel is the same for all of the shocks.
    OME, 5100, & 5160s
    Extended 25”
    Collapsed 15”
    Falcon & 5125
    Extended 27”
    Collapsed 17”
  13. Jan 2, 2019 at 6:04 PM
    Stewie
    Stewie New Member
    2016 Crew Max
    :thumbsup:. Post up picks when you’re done
  14. Jan 3, 2019 at 3:26 AM
    Red_Leg
    Will
    Will do. I get home in March. So I will probably do the install in early April.
  15. Jan 16, 2019 at 8:18 PM
    iamsmokey
    iamsmokey Smokey the Tundra
    Oahu, HI
    2018 Cement SR5 Off-Road 4x4 Crewmax
    A rep from wheelers said that 5160's are good for 0-2" they have the same specs as the OME shocks (as mentioned before)
    That made me finally decide on 5160's since my rear suspension setup might be 1.5-2" of lift
  16. Jan 19, 2019 at 12:04 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I went with the ICON’s that give 0-3” range in case I want to add a little more rake. I’m up about 2” in the rear right now.
    Maven4x4 likes this.
  17. Apr 17, 2019 at 7:20 PM
    Mr. Cade
    Mr. Cade New Member
    2014 Crewmax Platinum
    Next week, i'm installing 6112's with 5160's and OME Dakar leaf springs with stock shackles.
    I'll post pics here for posterity.
  18. Apr 20, 2019 at 3:46 PM
    iamsmokey
    Oahu, HI
    Can't wait to see the pics! Was debating the OME packs but I thought they lift the rear too high for the 5160's?
  19. Apr 20, 2019 at 7:54 PM
    Mr. Cade
    Mr. Cade New Member
    I think maybe they do, if you're running the bed open/stock. But I have the shell and rack and bedslide so hopefully it balances out. If it's too high, I'll just add more camping gear.
    :turtleride:
    wayoutwanderer likes this.
  20. May 22, 2019 at 6:38 PM
    Trailgoblin
    Trailgoblin New Member
    2013 rockwarrior double cab
    Dirt, and trail building tools.
    This is what i’m looking to do with my truck, trying for more like 2 to 2-1/2in the front, I just need more payload in the rear.
  21. May 22, 2019 at 10:43 PM
    Mr. Cade
    Mr. Cade New Member
    So, it's been about a month and I gotta say, I'm very happy. I love the ride quality and handling. The truck feels "snappier"...for lack of a better word. Let me know if I can provide specific pictures to help. I'll answer questions as best I can
  22. May 22, 2019 at 11:19 PM
    TundraTEX518
    TundraTEX518 New Member
    Tay
    19 LTD CM 4x4
    What roof racks are you running?
  23. May 22, 2019 at 11:20 PM
    Mr. Cade
    Mr. Cade New Member
    Those are Prinsu Design Studio racks.
  24. May 22, 2019 at 11:21 PM
    TundraTEX518
    Tay
    19 LTD CM 4x4
    They look good!! Pretty reasonably priced?
  25. May 22, 2019 at 11:23 PM
    Mr. Cade
    Mr. Cade New Member
    TundraTEX518[QUOTED] likes this.
  26. May 23, 2019 at 1:57 PM
    Broncobroke
    Broncobroke Super White Power
    Charlie
    Piedmont, NC
    2017 White Tundra 1794
    Trucks looks great. Are you running the overload spring with them? I have the same set up but also have decked drawers.
  27. May 23, 2019 at 2:06 PM
    Mr. Cade
    Mr. Cade New Member
    Thanks Bronco,
    I am not running the overload spring... Yet
    The leafs are not quite as "smiley" as I would like them to be, but at the same time, the truck is sitting higher than I'd like (for daily driver business).
    Soooooo, I may add sumo springs into the mix later, or perhaps OME OL springs.
    All that being said I think this setup puts the front and rear at ideal heights. Coming from A Tundra with a 7" lift I am much happier now. Ride and handling are terrific. My only complaints are personal gripes stemming from bad life choices.
    Black Wolf and Smiley like this.
  28. May 23, 2019 at 2:14 PM
    Broncobroke
    Charlie
    Piedmont, NC
    :D Too funny. I certainly understand that.:anonymous:
  29. Feb 28, 2020 at 2:46 PM
    Mr. Cade
    Mr. Cade New Member
    Just thought I'd update my end of this thread.
    Since I last posted, I have done 3 things that have made this truck feel and perform PERFECT.
    (Obv IMHO)
    1) I added SumoSprings Coil springs into my bilstein 6112s
    2) I swapped out the OEM bump stops for Wheelers Offroad Superbumps
    3) I swapped out the rear bumps for Black SumoSprings Rear springs.
    This truck, for my purposes is incredible now.
    It snaps back to level very quickly without any hard jolts. Body/bed roll is down to a minimum without it being too stiff and I never ride axle now.
    I honestly believe this is one of the best setups you can build for a daily driver, that also tows a trailer, and also goes offroading but also parks in a structure fairly regularly. I'm sure there's a nicer, more perfecter build... But I'm here to tell you, I for one am not looking for it. I'm very happy now.
    Here's my setup , in a nutshell
    Hope this helps someone.
    Cooper Discoverer S/T MAXX Radial... https://www.amazon.com/dp/B00MXNOOV8?ref=ppx_pop_mob_ap_share
    [These tires are amazing...again, for a DD that also offroads]
    FUEL Zephyr BD -Matte BLK Wheel with Painted (17 x 9. inches /5 x 150 mm, 1 mm Offset) https://www.amazon.com/dp/B07GT79S5R/ref=cm_sw_r_cp_apap_RVpQeDgnNS18q
    Bilstein 6112 Strut & Spring + Rear 5160 Reservoir compatible with 07-16 Toyota Tundra https://www.amazon.com/dp/B019NLP8UI/ref=cm_sw_r_cp_apa_i_dtzwEb451NQ3F
    Old Man Emu CS055R Spring https://www.amazon.com/dp/B00HR0FMOK?ref=ppx_pop_mob_ap_share
    [YES, these f@ckers squeak... still working on that]
    SSR-610-47 | SumoSprings Rear for Toyota Tundra, Toyota Tacoma, Nissan Frontier, Nissan Titan https://www.amazon.com/dp/B0152VDVAM/ref=cm_sw_r_cp_apa_i_onzwEbE18QWAK
    CSS-1069 | Coil SumoSprings for various applications | 0.69 inch inner wall height https://www.amazon.com/dp/B009JC42P4/ref=cm_sw_r_cp_apa_i_RnzwEbN8R756P
    Replacement front bump stops.
    Luckydog and jordan0317 like this.
  30. Mar 8, 2020 at 2:30 PM
    Mr. Cade
    Mr. Cade New Member
    Here's the back of my CM, loaded with steel shelves from Costco (760lbs) +the shell +a bed slide. So let's call it 1000lbs safely . You can see the SumoSprings are helping, but not to much. That's almost all OME springs.
    BajaTurd likes this.
