5160 Bracket?
Discussion in 'Suspension' started by Hartsy8, Oct 9, 2020.
  1. Oct 9, 2020 at 7:24 PM
    Hartsy8
    Hartsy8 [OP] Resident Hockey Guy
    Max
    2020 MGM 1794
    Anyone have a suggestion for what to use for the bottom bracket or if it is needed? Got them installed but don’t want to run long without the lower bracket.
  2. Oct 9, 2020 at 7:26 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    You could move the bracket to the center, leave the clamps where they are, and gently tighten each side until they are even and snug.
  3. Oct 9, 2020 at 7:26 PM
    Hartsy8
    Max
    2020 MGM 1794
    Great idea!!
  4. Oct 9, 2020 at 7:34 PM
    AZBoatHauler
    So.Arizona
  5. Oct 9, 2020 at 7:39 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Hartsy8[OP] likes this.
  6. Oct 9, 2020 at 8:01 PM
    Hartsy8
    Max
    2020 MGM 1794
    You guys know I’m fancy haha those are perfect. They look like they just pop right on?
    kparrow likes this.
  7. Oct 9, 2020 at 8:13 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    That’s the thought is they just tighten down with the center bolt. supreme comes in blue, black, and silver
    AZBoatHauler likes this.
  8. Oct 9, 2020 at 8:27 PM
    Hartsy8
    Max
    2020 MGM 1794
    Purchased. Thanks man!
  9. Oct 9, 2020 at 8:27 PM
    AZBoatHauler
    So.Arizona
    I’ve been running the Bilstein ones for about a year and a half with zero issues. Two screws and your done.
    Hartsy8[QUOTED][OP] likes this.
  10. Oct 18, 2020 at 4:31 PM
    Hartsy8
    Max
    2020 MGM 1794
    Got these and threw them on. How tight should they be? Is it possible to over tighten and damage shock? Don’t want to inadvertently do any harm.. thanks!
  11. Oct 18, 2020 at 5:39 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Just snug them up. They are aluminum so you can easily break or strip the threads if you go to tight.
  12. Oct 18, 2020 at 6:02 PM
    Hartsy8
    Max
    2020 MGM 1794
    Not as worried about the clamp as I am about the shock. But that’s good to know!! Shock should be fine?
  13. Oct 18, 2020 at 6:06 PM
    Danman34
    Danman34 New Member
    Danny
    Nah. Shock will be fine. The bracket is a far softer metal than the shock body is made of.
  14. Oct 18, 2020 at 6:11 PM
    Hartsy8
    Max
    2020 MGM 1794
    That puts me at ease. Appreciate it man!
