5100's w/Eibach coils
Discussion in 'Suspension' started by DK33, Dec 21, 2018.
  1. Dec 21, 2018 at 11:16 AM
    DK33
    DK33 [OP] New Member
    David
    Baltimore MD
    2018 TRD Sport MGM
    Blacked out badges, console organizer with shelf, cleanable cabin air filter, all weather Matt's, Under seat storage. Tinted front driver/passenger windows to match rear. Tacotunes amp with single 10"Sub. Sound matting all doors and rear. Component speakers all 4 doors. AJT climate Knobs, AJT Shifter and cup holder Black. shorty antenna. Method NV 18X9 / 295/70/r18 Falken Wildpeak at3w. 3" upfront 1.5 Shackles rear.
    Need some help with what to do. I have purchased but not installed 5100's for all 4 corners. Also I purchased Eibach coils. I was advised to set the 5100 on lowest setting and with the Eibach should gain 2" lift. My question is should I go this route or get the Eibach pro truck shock that can be set at 2" or 3"? Also is it safe to put the 5100 on 2nd setting? Thanks for your insight this is new to me so I'm trying to get it right and not cost myself more in the long run.
    Thanks
    ab1653 likes this.
  2. Jan 24, 2019 at 9:06 PM
    ab1653
    ab1653 Ew member
    TX
    2014 Tundra
    Following.
  3. Jan 24, 2019 at 9:28 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    A true adjustable coil over would perform better and you can adjust the height, but the 5100s and eibach coils are a good choice. Not sure what the price difference would be, but that's up to you. For me 2 inches if lift would be just fine.
    You do NOT want to set the 5100s on anything other than the lowest setting when also adding lift coils, you'll preload them and it will ride like crap and also stress the shocks and risk failure and thats not good.
  4. Jan 25, 2019 at 6:38 AM
    ab1653
    ab1653 Ew member
    TX
    2014 Tundra
    Do you have the part # for those Eibach coils?
    DK33[QUOTED][OP] likes this.
  5. Jan 25, 2019 at 7:05 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    OP, did the 5100s and coils come from Toytec?
    Is there a reason you went this route instead of just going with the Toytec/eibach assembled coilovers?
  6. Jan 25, 2019 at 7:12 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I would call bilstein and ask. The 5100 was designed with stock coil in mind. Putting a longer coil could bind at full compression or push the shock past full extension.
  7. Jan 29, 2019 at 2:52 PM
    DK33
    David
    Baltimore MD
    2018 TRD Sport MGM
    @OBXTundra I got the coils from Toytec but the 5100's from someone else. Hindsight I probably should have went with the Toytec/Eibach coilovers from the jump.
    I should add I spoke with Dave @toytec and he was super helpful in answering my questions. Great company in my experience so far with them.
    OBXTundra likes this.
  8. Feb 19, 2019 at 9:31 PM
    ab1653
    ab1653 Ew member
    TX
    2014 Tundra
    Any status on how the Eibach with the 5100s worked out?
  9. Feb 19, 2019 at 9:37 PM
    DK33
    David
    Baltimore MD
    2018 TRD Sport MGM
    Haven't installed them yet. I'll update the post when I get everything up and running.
  10. Mar 19, 2019 at 9:54 PM
    oneup
    oneup New Member
    Cincinnati
    17 cm
    Any update on this set up?
  11. Mar 19, 2019 at 10:04 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
  12. Mar 20, 2019 at 12:52 AM
    Jimshorts
    Jimshorts New Member
    Your warranty for the 5100 is now no good. I think the bilsteins are junk. I've rolled the snap ring that couldnt be done...if I remember the Titanic couldn't be sunk either. I have since went to the old manspring and strut. Love it. Good luck with your set-up
  13. Mar 20, 2019 at 5:19 AM
    oneup
    oneup New Member
    Cincinnati
    17 cm
    How’s ride compare to stock spring w/ 5100?
    poheller likes this.
  14. Mar 20, 2019 at 3:45 PM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    That great, exactly what I am going to do..
    dcsleeper408[QUOTED] likes this.
  15. Mar 30, 2019 at 7:59 AM
    snarkscarbine
    snarkscarbine New Member
    Alex
    Dallas
    2014 Silver Sky CM Ltd 4x4
    Bilstein 5100s Footwell LEDs Fold-A-Cover g4 elite TRD 18s
    Also curious.
  16. Mar 30, 2019 at 8:45 AM
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
