5100s vs Eibach
Discussion in 'Suspension' started by Bust, Jul 15, 2019.
  1. Jul 15, 2019 at 11:41 PM
    Bust
    Bust [OP] New Member
    Shean
    2013 Black Toyota Tundra Rock Warrior
    I'm looking at getting a leveling kit for my 13' RW so I can put on bfg 285/65/20 AT. Been browsing toytech and wanted to see which are better or if there is any real difference between the two? Looking to get around a 2" lift on the front and kicking the idea around and upgrading the front springs with the Eibach? So either the 5100 or eibach pro truck sport shock, leaving the stock spring or upgrading to the eibach spring or just getting the eibach complete coilover. I'm undecided and don't know what will be good/better/best within my price point of around $500. If I don't do the coilover, that leaves money to upgrade the rear shocks from stock.
    I don't do much offroading, just camping, eventually will haul a 18' ish rv and daily driver. Any info is greatly appreciated, thanks!
  2. Jul 16, 2019 at 8:18 AM
  3. Jul 16, 2019 at 8:37 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Its always better to do a full coilover system over a stock spring pre-load for ride quality purposes, but with that being said, the Eibach shocks by themselves will justify perfectly for you no problem if you are simply looking to level out the Tundra.
    We do offer the early 2nd gen Eibach full coilover assemblies here in stock right now for a solid 2'' of lift over stock with new springs and shocks for $512.00, great riding coilover system without going overkill on budget! Let me know if you have any questions.
    -David
    T-Rex266 likes this.
  4. Jul 16, 2019 at 10:24 AM
    Bust
    Shean
    What is the difference between the coilover and either using the bilstein 5100 with the eibach pro lift coil spring or eibach leveling shock and pro lift coil?
  5. Jul 17, 2019 at 7:38 PM
    2chains
    2chains New Member
    Southern Ablerta
    ^^I'd be interested to know as well
    Rica25 likes this.
  6. Jul 17, 2019 at 10:02 PM
    Bust
    Shean
    I actually decided to go with fatbobs garage 3" coilovers.
