500w power inverter in center console
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Kayaking Tundra, Feb 21, 2021.
  1. Feb 21, 2021 at 8:36 AM
    Kayaking Tundra
    Kayaking Tundra [OP] New Member
    2019 White Toyota Tundra TRD PRO
    I am thinking about installing a 500w-750w power inverter in the center console plugging in to the 12v thats in the center console, mounting the inverter in the console on the passengers side.
    My thought is to have 2 portable charging small LED work lights, always charging (when the truck is running.)
    work light
    Then have a USB charging flashlight also, when the truck is running.
    flashlight
    Its the stock battery and I dont know that I would use the 500w, 110 outlet, other than charging my tablet.
    Anyone have any ideas?
    Thinking about this one...
    here
  2. Feb 21, 2021 at 8:39 AM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    You don't need an inverter for that. I have a flashlight, emergency cell phone, and dual band radio all plugged in and charging when the truck is on and no inverter to be found.
    You're going to take 12v, invert it to AC, to plug in a charger that converts that AC to DC to then charge the devices.
    1lowlife and NewImprovedRon like this.
  3. Feb 21, 2021 at 8:46 AM
    Kayaking Tundra
  4. Feb 21, 2021 at 8:56 AM
    eick
    eick New Member
    You can also swap out the jack in the console for one that has USB ports. Instead of using that adapter.
    But the adapter is cheap and easy.
    1lowlife likes this.
  5. Feb 21, 2021 at 9:01 AM
    Kayaking Tundra
  6. Feb 21, 2021 at 9:08 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  7. Feb 21, 2021 at 9:11 AM
    P-Factor
    P-Factor New Member
    Besides all of the above, inverters are air cooled and require good ventilation, mounting inside a center console will not provide adequate cooling.
    Kayaking Tundra[OP] likes this.
  8. Feb 21, 2021 at 9:30 AM
    Kayaking Tundra
    I think that will suffice my needs. I just would like to have a system thats always charging flashlights, work lights, and a small battery pack.
    I have a story that happened a few years ago, when I needed light in a serious way, but didnt have anything with me.... now, I always have lights with me. Plus I hunt, fish, and kayak a lot, any way I can charge lights is a positive way, and this is just another way.
    I do think a long term 2000w inverter is something I want, just to have, Id like to mount a separate battery/inverter mounted in the decked system, that I can somehow charge via flex solar panels on the roof of the truck. Now that is idea...any overlanders have something like that?
  9. Feb 21, 2021 at 12:37 PM
    eick
    eick New Member
    Yea secondary battery is pretty easy until you get in to trying to charge it from the main. Then it’s still not hard just requires planning and the right parts.
    Here’s a good one on adding inverter -
    https://www.tundras.com/threads/110v-outlets-in-bed-and-console-write-up.37500/
    I think the dual battery setup has been covered pretty well shouldn’t be hard to find a good write up on it.
