5.7l Crewmax with factory brake controller question
Discussion in '2.5 Gen Tundras (2014-2021)' started by AirSchatz, Jul 19, 2020.
  1. Jul 19, 2020 at 1:14 PM
    AirSchatz
    AirSchatz [OP] New Member
    I would like to replace my factory brake controller, which did not work with my trailer, with the Tekonsha P3, I have the controller and need a harness to plug into the Tundra wiring. Is there such a creature?
  2. Jul 19, 2020 at 1:24 PM
    AZTundra
    Paul
    Phoenix, AZ
    Yes, there are harnesses to connect the p3 to the Tundra.
  3. Jul 19, 2020 at 1:27 PM
    AZTundra
    Paul
    Phoenix, AZ
  4. Jul 19, 2020 at 1:30 PM
    AirSchatz
  5. Jul 19, 2020 at 2:02 PM
    AZTundra
    Paul
    Phoenix, AZ
    I believe you need the 3040p
  6. Jul 19, 2020 at 3:11 PM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    I thought you had to do a cut and splice for the 2018 and later Tundra because of the two piece unit. The dash unit and the passenger lock panel unit.
  7. Jul 19, 2020 at 3:13 PM
    AirSchatz
    There's another part to the brake controller? I removed the actual controller, just below the "TOW/HAUL" button, where is the passenger lock panel unit located?
  8. Jul 19, 2020 at 3:18 PM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    I haven't seen it personally, just recall reading about on here, someone replaced their unit with aftermarket and another had it replaced under warranty. You will need to search for the threads.
