5.7 won't start when hot
Discussion in '2nd Gen Tundras (2007-2013)' started by Ryder, Aug 29, 2021.
  1. Aug 29, 2021 at 9:01 AM
    Ryder
    Ryder [OP] New Member
    2007 Tundra with 2014 wheels Smittty built bumper and winch
    Anytime the weather is warm enough to use the AC the engine overheats and won't start after shut off. Once even went into limp mode and had to tow it home. Always starts after cold.
  2. Aug 29, 2021 at 9:44 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    If the engine goes into limp mode, you should be able to pull codes from the ECU to give you some hints.
  3. Aug 29, 2021 at 11:57 AM
    Ryder
    Of course that was the first thing I tried. It is throwing no codes.
  4. Aug 29, 2021 at 1:05 PM
    audiowize
    Paul B.
    Well, your best bet is to figure out why the truck is overheating. There are a bunch of things that you should check, and I would recommend checking all of them.
    1. Get an exhaust gas in the coolant detector kit to be sure your head gaskets are OK.
    2. Is the engine driven cooling fan spinning?
    3. Is the radiator super dirty and plugged up?
    4. Is the coolant level in the radiator full? (check this with the engine cold)
    5. Does the truck overheat with the thermostat pulled out? When you pull out the thermostat, you can put a pot of cold water on the stove with the thermostat and a thermometer in it and slowly heat it. There are specifications for when the thermostat should open.
    6. Tundras are somewhat known for needing the occasional water pump replaced. I would inspect your water pump thoroughly for leaks and possibly pop the serpentine belt off to check for play in the water pump pulley.
  5. Aug 29, 2021 at 6:15 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Check the Cats.
