5.7 V8 Overheating?
Discussion in '2.5 Gen Tundras (2014-2021)' started by mart1nezdaniel, Jul 18, 2018.
  1. Jul 18, 2018 at 2:48 PM
    mart1nezdaniel
    mart1nezdaniel [OP] AZ
    Arizona
    Tundra TRD PRO 2017
    Is there any truth to this?
    Email from my brother who owns a Sequoia:
    "Called Toyota service advisor said not to let your truck idle too long, it could over heat like mine did on the way back from Rocky Point. I guess its common with the bigger engines he said."
    This is the first ive heard of our 5.7L engines. Any experience the same?
  2. Jul 18, 2018 at 2:52 PM
    I call bullshit.
    This is not normal. I idled my 12’ sometimes all day while working on our mountain property.
  3. Jul 18, 2018 at 2:59 PM
    TheBeast The Beach
    never heard of that
    kenomouth64 likes this.
  4. Jul 18, 2018 at 3:00 PM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    Definitely not true
    UNTMatt and kenomouth64 like this.
  5. Jul 18, 2018 at 3:00 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Overheating at idle isn't normal.
  6. Jul 18, 2018 at 3:07 PM
    mart1nezdaniel
    Arizona
    Tundra TRD PRO 2017
    yeah, same thoughts here.
  7. Jul 18, 2018 at 3:17 PM
    HUTCHJ
    HUTCHJ I can ride my bike with no handlebars
    J
    Nah, not normal at all. You check your coolant level?
  8. Jul 18, 2018 at 3:40 PM
    mart1nezdaniel
    Arizona
    Tundra TRD PRO 2017
    No the problem wasn't mine. My brother had his sequoia serviced at toyota just last year and had them flush his coolant. Sounds like they are feeding him BS.
    kenomouth64 and NewImprovedRon like this.
  9. Jul 18, 2018 at 3:46 PM
    HUTCHJ
    J
    Sounds like he has a leak or the thermostat is stuck.
  10. Jul 18, 2018 at 3:46 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    If it were to overheat at idle only, or at low speeds only, it would be in indication of a failed viscous fan hub.
  11. Jul 18, 2018 at 3:56 PM
    mart1nezdaniel
    Arizona
    Tundra TRD PRO 2017
    "No leaks Toyota did a radiator flush and changed the tubing to the radiator last year and I paid like $400 bucks for that last year when they did the breaks….for that exact reason I had them do it so it wouldn’t overheat."
  12. Jul 18, 2018 at 3:59 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Mine is my work truck and I idle it for extended periods without issue.
  13. Jul 18, 2018 at 4:00 PM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    The other day at work, it was 90 degrees out, and we were using a company Ford Explorer (2015) to keep cool when we could get out of the sun. The truck idled for 2 hours before the engine began making a horrible grinding noise and white smoke began pouring out form under the hood. I guess that's why they call them Exploders.
  14. Jul 18, 2018 at 4:02 PM
    mart1nezdaniel
    Arizona
    Tundra TRD PRO 2017
    well, its a bit hotter than 90 here in AZ. Its consistently over 105 every day.
  15. Jul 18, 2018 at 4:03 PM
    Max Power
    I know, I was just bringing that story up for the sake of having a laugh at Ford.
  16. Jul 18, 2018 at 5:59 PM
    Smoofers
    Smoofers New Member
    N TX
    2018 TRD Sport
    I'm calling BS as well. I regularly idle my '07 at lunch in 105 degree heat and my temp gauge never goes past half. The cooling system on the 5.7L is very well setup. I'd check your coolant level. Other possibility could be a faulty fan clutch.
  17. Jul 18, 2018 at 6:19 PM
    Sas
    OKC, OK
    Could be a number of things really. Overheating can also be caused by fluid not getting around the engine and thru the system efficiently. This can be from a problematic thermostat, a bad water pump, an obstruction or air trapped in the system. Having been over a year though I kind of doubt it's the air option though (unless there's a leak and the fluid level is really low now).
  18. Jul 18, 2018 at 6:19 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    New hoses and flush on a 2017? I have Led bars covering 2/3's of opening on mine. 104 today and temp gauge sat in same place it always does.
  19. Jul 18, 2018 at 6:29 PM
    Azblue
    The Dirty T ( ^_^)_且
    Dude, I'm in Tucson. If you are also in Tucson please tell me which of the 2 dealers here told you this BS so I can make sure that I never visit their service dept.
  20. Jul 18, 2018 at 6:33 PM
    mart1nezdaniel
    Arizona
    Tundra TRD PRO 2017
    No this was for my brothers 08' sequoia
  21. Jul 18, 2018 at 6:34 PM
    mart1nezdaniel
    Arizona
    Tundra TRD PRO 2017
    Dealer in avondale
    Sas likes this.
  22. Jul 18, 2018 at 6:42 PM
    Pale_Horse
    Pale_Horse Sooooooooo White.
    FL
    White 2013 TRD OR 4x4 DC
    Cupcake chit.
    Just no.
  23. Jul 18, 2018 at 8:10 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    And what dealership was it? Not to call them out but for the rest of us locally to avoid.
  24. Jul 19, 2018 at 9:20 AM
    mart1nezdaniel
    Arizona
    Tundra TRD PRO 2017
    I think avondale toyota. in AZ
  25. Jul 19, 2018 at 9:36 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Sounds like dealership up-selling. They put fear into the customer to sell 'em unnecessary service. It's a lot easier to put fear in than to remove it from peoples minds.
    landphil likes this.
  26. Jul 19, 2018 at 9:54 AM
    As others have stated, this is what I would be looking at:
    Fan clutch operation
    Radiator condition, here in CO it’s never a bad thing to pull the radiator out every 4 years, clean the ice melt road grime.
    Depending on mileage, water pump.
    This is a long shot, but have your BIL remove radiator cap when cold, start vehicle and warm up. Rev up motor to 1500 rpm or greater and leave there. Check the radiator for bubbles. If he sees bubbles, head gasket time.
    T-Rex266 likes this.
