5.7 Tundra oil gage fluctuating
Discussion in '2nd Gen Tundras (2007-2013)' started by Filo, Feb 25, 2020.
  1. Feb 25, 2020 at 1:31 PM
    Filo
    Filo [OP] New Member
    2007 Tundra 5.7
    Hi guys, i just got a 2007 5.7 tundra and the oil pressure move pass the center when engine is cold or when I down shift for more speed, i just replaced the sending unit but still the same. is that normal on this trucks?
  2. Feb 25, 2020 at 1:45 PM
    timsp8
    NY
    It will fluctuate depending on engine rpm. Should be just above or below center. Right at center when cruising. Mine never goes above or below 1/4 and 3/4 marks.
    TTund16 and Zebruaj like this.
  3. Feb 25, 2020 at 2:50 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Makes sense to me that the pressure could be higher when the engine and oil are cold or RPM is higher.
    GNTundra likes this.
  4. Feb 25, 2020 at 2:50 PM
    FredB32
    FredB32 New Member
    2011 TRD RW
    Mine has done the same thing on both Tundras I've owned, so it seems normal.
  5. Feb 26, 2020 at 8:37 AM
    Black4X2
    Black4X2 New Member
    Bill
    2007 Black Tundra Limited 4X2
    Absolutely normal.
  6. Feb 26, 2020 at 8:39 AM
    mech_engineer09
    mech_engineer09 Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    Yes completely normal to have it above or below when doing anything but cruising.
  7. Feb 27, 2020 at 8:25 PM
    Filo
    2007 Tundra 5.7
    Thanks guys for the reply
  8. Feb 28, 2020 at 11:27 AM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    When you down shit do you leave skid marks!
    TTund16 likes this.
  9. Mar 16, 2020 at 1:38 PM
    Filo
    2007 Tundra 5.7
    oil pressure on the highway after new oil Sensor
  10. Mar 16, 2020 at 1:45 PM
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    Based on your temp gauge it looks like your not in the “cold start mode”. We’re missing the RPM side to get the full picture here but even when warm I’m not sure I go past the middle mark.
  11. Mar 16, 2020 at 2:02 PM
    timsp8
    NY
    What was your rpm? Have you checked your oil level to make sure it’s good?
