5.7 to 4.7 swap?
Discussion in '2nd Gen Tundras (2007-2013)' started by Hammy323, Jul 10, 2024.
  1. Jul 10, 2024 at 8:51 AM
    Hammy323
    Hammy323 [OP] New Member
    Jon
    2007 Tundra
    Na
    Hi all,
    I currently have a 2007 tundra with the 4.7 and 2 wheel drive. Engine and trans are prefect still.
    But came across a 08 that had a blown up 5.7 engine but the overall condition of the truck body, frame and interior are in better condition.
    My question is. Can I swap in my 4.7 into the other truck?
    Thanks
  2. Jul 10, 2024 at 9:04 AM
    Not for the feint of heart. Are the two trucks otherwise identically equipped? Same cab config and drive type?
    Retired...finally likes this.
  3. Jul 10, 2024 at 9:05 AM
    Retired...finally
    Anything can be done and having a donor only 1 year different will be a big help.
  4. Jul 10, 2024 at 9:11 AM
    Hammy323
    Jon
    2007 Tundra
    Na
    The 08' is a 4x4. The trans is still good.
  5. Jul 10, 2024 at 9:18 AM
    The trans for the 4.7 is a 5 speed and the trans for the 5.7 is a 6 speed. Not compatible.
    blenton and Hammy323[QUOTED][OP] like this.
  6. Jul 10, 2024 at 9:31 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I suppose it’s possible, but you would have to swap over the entire engine and chassis harness, along with any and all ECU’s and sensors. No telling what what would happen when it comes time for emissions testing and DEQ is scratching their heads trying to make sense of the emission readings.
  7. Jul 10, 2024 at 9:33 AM
    The 4.7 will not mate to the 5.7 transmission. You would have to gut the drivetrain, 4wd system included, and install your 2WD 4.7 drivetrain and all associated harnesses and computers. Second option, Sell your 2007 and use the proceeds to buy the 2008 and a donor 5.7 engine to replace the blown one.
    YotaMan likes this.
  8. Jul 11, 2024 at 9:46 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Maybe the transmission can fit, by swapping bell housings, It will still be a lot of work.... In Cali you would have to go through CARB but since it was an option for the truck, it shouldn't be an issue. Matching things together will probably be a challenge. But if you don't need the truck long term there is room for trial and error.
  9. Jul 11, 2024 at 10:14 AM
    How you gonna get the computers to talk to each other? ECM and TCM wouldn’t know what to do with each other.
  10. Jul 11, 2024 at 11:39 AM
    blackdemon_tt
    Don't think it would be too hard... Splicing wires? I mean, swapping my 4speed for a 5speed transmission was the same plug with same color codes, only difference is Overdrive light flashes in 5th gear, both computers still talk to each other. 92 to a 97 5 year difference primitive electronics and they function well with each other. These are apples to oranges, but following wire diagrams shouldn't be too hard, theoretically...
  11. Jul 11, 2024 at 5:59 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    I agree with the sell the 4.7 Tundra and buy a 5.7 model unless you really want an involved project
  12. Jul 11, 2024 at 6:26 PM
    Keep the 07, buy the 08, and put a motor in it.
    blackdemon_tt and Oolypoolay like this.
