5.7 Timing Chain Noise on cold start
Discussion in '2nd Gen Tundras (2007-2013)' started by Danssmallengine, Feb 10, 2022.
  1. Feb 10, 2022 at 7:39 PM
    Danssmallengine
    Danssmallengine [OP] New Member
    I had rattling noise that came from the front of the engine on cold start. It continued to get worse over time until it got pretty bad. Here it is:
    https://youtu.be/UlAA17ybzTQ
    Turns out to be loose cam chains (both lower chains) caused by stuck tensioners. I replaced all 4 chains, tensioners and guides and its perfect now. Horrible job to do but this video might help you through the gotchas.
    https://youtu.be/CEwUC7cxGz8
    CaLan87, baraynavab, Mobeyk and 2 others like this.
  2. Feb 11, 2022 at 4:26 AM
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    That’s impressive work! I’ve done a lot of wrenching over the years, but this one might be above my level.
  3. Feb 11, 2022 at 8:20 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    I hope to never be into my 3uz that deep, but good on ya!
    Was expecting to hear the somewhat startling rattle Ive got for about 2 seconds upon some cold starts (20-30 deg F), but that coming and going, well after start up is definitely not what I am experiencing.
    Kinda seems like all of these fancy vvt systems have a tendency to clatter a bit until oil pressure comes up.
    Glad you got all fixed up
  4. Feb 11, 2022 at 8:31 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    My Tundra is fairly quiet at 266k miles, but 2014 Camry at 172k?.... definite rattle at startup and first start after an oil change hurts me in my soul :oops:
  5. Feb 11, 2022 at 5:28 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    Yeah I have that rattle a little bit on Georgia Cold mornings...you explained it really well.
    Btw one suggestion to the video you recommended is to put it in the comments section as well. the 2nd video you mentioned is here.
    https://www.youtube.com/watch?v=oaDWBwmtVEE
  6. Feb 11, 2022 at 6:01 PM
    baraynavab
    Atlanta
    oh I also forgot to mention.. after watching the video this is procedure as hard than doing the timing belt replacement on the Toyo 4.7l v8 2uz-fe engine. Make sure you follow the procedure and you should be okay.
    BTW @Danssmallengine do you happen to have the toyota tech instructions on this? it would be great if you can post it so we all can benefit.
    Thanks
    PS. Looks like I found the instructions to do this online via this link just in case you need it. https://www.tundratalk.net/threads/2008-5-7-timing-chain-tensioner-replacement.762018/page-3
