5.7 oil issue
Discussion in 'General Tundra Discussion' started by 5.7hurtz, Aug 5, 2024.
  1. Aug 5, 2024 at 10:26 AM
    5.7hurtz
    5.7hurtz [OP] New Member
    Hello so I changed my oil 2 time through the oil filter ONLY figured out that it had too much oil and was blowing a little bit off smoke, drained some out it was ok than I changed with the correct amount of oil now its like a smokehouse, and the engine has the shakes. HOW CAN I SAVE MY TRUCK!!!
  2. Aug 5, 2024 at 10:36 AM
    AZBoatHauler
    So.Arizona
    Drain the oil. See how much comes out. If you’re past that, how much came out when you drained it?
  3. Aug 5, 2024 at 10:37 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Thru the filter again?
    BillyB and Tripleconpanna like this.
  4. Aug 5, 2024 at 10:37 AM
    AZBoatHauler
    So.Arizona
    Let’s try the drain.
  5. Aug 5, 2024 at 10:38 AM
    Mr Badwrench
    Mr Badwrench New Member
    You probably fouled the plugs into oblivion, hence the shake. That should go away after a little bit of driving. Do you have any leaks?
    Drain the oil to the right level, let it sit for couple hours then see if the shake gets better.. I'd probably just change the plugs after you've corrected the oil situation.
    Bob and Jim LE 1301 like this.
  6. Aug 5, 2024 at 10:38 AM
    FrenchToasty
    Mo
    Bone stock
    :amen:
  7. Aug 5, 2024 at 10:40 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    So you didn't use the drain plug to drain the oil in your truck?
    You only drained from the oil filter?
    Then you added 8.5 qts of oil?
    FrenchToasty likes this.
  8. Aug 5, 2024 at 10:46 AM
    AZBoatHauler
    So.Arizona
    Can’t say I’ve ever tried - but I think you get less than a quart if you just drain the filter.
    :eek2:
  9. Aug 5, 2024 at 10:51 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    That's what I'm thinking. It can't be a whole lot coming out of there. Unless you start the truck up, haha.
    Retired...finally likes this.
  10. Aug 5, 2024 at 12:51 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    This should be interesting if OP comes back with an update.
    Oh yeah, and welcome from VA.
    Bob likes this.
  11. Aug 5, 2024 at 1:03 PM
    :eek2::eek2:Can't believe I'm gonna say this, but..... take it to an oil change place :eek2::eek2:
  12. Aug 5, 2024 at 1:07 PM
    AZBoatHauler
    So.Arizona
    Maybe the first time that’s been the correct answer.
  13. Aug 5, 2024 at 1:19 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I'll be surprised if the OP responds.
  14. Aug 5, 2024 at 1:33 PM
    koditten
    Kirk
    Midland of the Mitten
    Now, now, boys. We were all new to vehicle maintenance at one time.
    My 1st oil change, I dumped the trans pan. Was my old man pissed!
  15. Aug 5, 2024 at 3:00 PM
    woods
    woods New Member
    2021 SR5 TRD Sport
    A forum is just for this type of thing. Guy tries to do something himself, makes a mistake and comes here for advice. What's the reward for a new member? A bunch of hot shot wise ass responses. A whole page of people who never made a mistake.
    T-Rex266 and Bob like this.
  16. Aug 5, 2024 at 3:19 PM
    woods
    woods New Member
    2021 SR5 TRD Sport
    You guys are right, there were a couple good responses at the start. It quickly snowballed from there. I guess I have seen the latter type of behavior from folks on this forum and TW from time to time and it just blows my mind. Its right up there with people who tell you to "just use google". Sure google will work, but if we want forums to continue and not have everything be youtube and facebook, people need to give some people a little more slack sometimes.
  17. Aug 5, 2024 at 3:27 PM
    Helps if OP EVER comes back to join in the discussion they started. Then it helps if after discussing the possible fixes, they come back and share what worked.
  18. Aug 5, 2024 at 3:31 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Hell, a great example of this forum is the head unit upgrade thread.
    Amongst many others.
    Tripleconpanna and AZBoatHauler like this.
  19. Aug 5, 2024 at 3:40 PM
    AZBoatHauler
    So.Arizona
    I respect your desire to make this a better place. Hopefully OP didn’t lose his engine.
    :fistbump:
    It’s funny whenever I see people complain about lack of camaraderie on the forum they usually have double digit posts and haven’t tired to help anyone.
    I talk to multiple people every day that I met here who are no longer forum friends - just friends.
  20. Aug 5, 2024 at 5:33 PM
    PermaFrostTRD
    Northern NY
    Meh, I understand and appreciate your altruism but if the OP can’t be bothered to post a question by typing, providing important details, and maybe just not using Siri exclusively, then it warrants a little ribbing. Besides, the engagement keeps the post on the front page encouraging views and maybe the OP will return and update us and we can be of better help.
    You rip on your friends, not people you don’t care about.
  21. Aug 5, 2024 at 5:50 PM
    bflooks
    bflooks New Member
    Metrowest MA
    So you're the one. You're the one who broke those artificial AOL chatroom barriers. A/S/L mean nothing here. :)
  22. Aug 5, 2024 at 6:07 PM
    Bob
    Bob Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    This...did a little cleaning since the guy is new.
    @5.7hurtz some good advice in here from folks who've done worse
  23. Aug 5, 2024 at 6:34 PM
    AZBoatHauler
    So.Arizona
    bflooks[QUOTED] likes this.
  24. Aug 5, 2024 at 6:43 PM
    ^^^^This^^^^
    But use the drain plug also.
    Welcome from NY.
    Bob likes this.
  25. Aug 5, 2024 at 7:28 PM
    5.7hurtz
    So I drained from the oil pan and replaced the 7.5 quarts it needed,, now it's throwing smoke I'm taking it to get diagnosed I'm hoping for a silver lining from this dumb mistake
    Rugerla1 and KNABORES like this.
  26. Aug 5, 2024 at 7:39 PM
    AZBoatHauler
    So.Arizona
    Do you know how many quarts were in it? Do you see any oil coming out of the engine or it’s just smoking? Running normal other than smoke?
    Once the crank starts to get submerged in oil, it will throw it everywhere as it spins and is a huge mess. There is a YouTube video with a window cutout showing what happens when you run an engine with excessive oil. They can take a lot - but obviously it’s not ideal. If it sounded okay I think you'll end up okay.
  27. Aug 5, 2024 at 8:01 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    You certainly wouldn't be the first to make a mistake, and you most definitely won't be the last... I don't believe the result will be too catastrophic. Good luck on an easy and relatively painless resolution :thumbsup:
  28. Aug 5, 2024 at 8:28 PM
    Mr Badwrench
    Assuming you haven't driven it 100 miles already, it is probably going to smoke for a little while. Is your check engine light on? If you're misfiring from fouled plugs, it probably will be. You're probably okay if you didn't fill it to the point that you have seal leaks.. which would take a lot.
  29. Aug 6, 2024 at 12:00 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    I hope you didn't cause any significant damage.
    I also hope you drained the engine oil and not the transmission fluid on the second attempt. Because, apparently that's easy to do on the Tundra. I've seen that thread on here before.
    I highly recommend you watch a good YouTube video or something before you attempt any more maintenance. Or ask lots of questions first. This forum has some insanely intelligent and mechanically inclined people on here. Most are more than happy to help you out.
  30. Aug 6, 2024 at 9:29 AM
    lalakai
    lalakai New Member
    2019 Tundra limited
    stock
    yeah, that was my thought also. but if he drained through the filter, then probably over filled it. Besides fouling the plugs, the added oil will generate more engine heat as it works harder to move through the added oil. And make sure you are checking the oil level on level ground, not while the vehicle is up on ramps.
