5.7 Oil drain plug loose(ish)
Discussion in 'General Tundra Discussion' started by jcic22, Aug 27, 2025.
  1. Aug 27, 2025 at 12:52 PM
    jcic22
    jcic22 [OP] New Member
    I do my own oil changes and use all OEM stuff. I notice on my '21 tundra that when I perform an oil change, the oil drain plug is not as tight as I remember it being. It's almost loose, just barely snug. I use the drain plug washers that have a blue finish on them. The finish on it almost disintegrates like paper when I remove an old one, revealing the silver metal washer.
    Today when I changed the oil in the wife's '20 Sequoia I noticed the drain plug bolt was very tight. The last oil change on her vehicle was done by a local shop who has done great work for us. I noticed they used a copper washer on the drain plug bolt when they last did it.
    After this observation I went to snug up the oil drain plug on the tundra which had an oil change a few days ago. I definitely snugged it up a bit more.
    Does anyone share a similar experience with the OEM drain plug washer? It's almost like it loses it's integrity leaving the drain bolt not as tight as it should be.
    I don't use a torque wrench when snugging these up, but I have a decent feel for snug tight without going so far as damaging the threads.
  2. Aug 27, 2025 at 12:58 PM
    2mchfun
    Prior to installing a Fumoto vavle, I never had an issue with the blue washers. They did stick to the pan though.
    des2mtn and AZBoatHauler like this.
  3. Aug 27, 2025 at 1:55 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    This ^^^.
    Get Fumoto (or equivalent) valves for your engine oil draining and never have to contemplate this conundrum again.
    Fobroader likes this.
  4. Aug 27, 2025 at 2:11 PM
    jcic22
    Not a good solution. I put one on the tundra for exactly one oil change interval. It took so long to drain the oil that the fumoto valve came off before it was even done draining because it took so long. I’ve got things to do, not wait around for 30min for the oil to finish draining. The longest part of an oil change without the fumoto valve is getting the stupid skid plate back on. Pain in the butt…
    I’ve had the blue washers stick to the oil pan before. No biggie. Just seems like the oil drain bolt feels looser over time compared to when I installed it. Curious if it was something any else noticed or not. Maybe it’s time to just get the torque wrench out and tighten it up per the spec….
    chugs likes this.
  5. Aug 27, 2025 at 2:13 PM
    2mchfun
    Check out the valvomax plug/valve, good stuff!
  6. Aug 27, 2025 at 2:14 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Drill a hole in the skid plate for the fumoto?
  7. Aug 28, 2025 at 8:00 AM
    seydou
    seydou Distinguished Member
    You could always try torquing it to the manufacturer's spec. But then you would be made fun of by simpletons for not knowing what you are doing, and having no business changing your own oil.
    :crapstorm:
  8. Sep 1, 2025 at 11:21 AM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    Sounds like the port is starting to strip with your next oil change you could replace the oil pan, tap it to a larger size( which I would remove to do so if you are removing the oil pan I would just replace it) or put a bunch of JB Weld or similar around the drain plug and use a fluid extractor for future oil changes
  9. Sep 1, 2025 at 12:10 PM
    jcic22
    Thanks. I’ll inspect the threads next time but I’m certain that isnt the case.
  10. Sep 1, 2025 at 4:25 PM
    seydou
    How would it be stripping out with just 4 years worth of oil changes? Over-tightening? That doesn't seem likely at all, given what's happening. There are many things I would consider and try before I go with removing/replacing/retapping the pan. And JB Weld would not be one of them, LOL.
    Inspecting the threads (should always be part of the procedure)
    Torque bolt to manufacturer specification
    Try a different bolt/washer
    Install Fumoto/ValvoMax/EZ Oil Drain
