5.7 motor mounts
Discussion in '2nd Gen Tundras (2007-2013)' started by Bonzen, Dec 16, 2019.
  1. Dec 16, 2019 at 9:22 AM
    Bonzen
    Bonzen [OP] Solid Offroad motor & transmission mounts
    Lake Havasu City, AZ
    These are in full production finally.
    Check out the Instagram page @solid_offroad for pictures and info.
    DM me for order info!
    Peeeheeuuu, GNTundra, jc153 and 3 others like this.
  2. Dec 16, 2019 at 9:27 AM
    Bonzen
    2007- current 5.7 & 4.6 tundra/sequoia
  3. Dec 16, 2019 at 9:40 AM
    Bonzen
    .250" thick flanges, grade 8 bolts.
    GNTundra, jc153, Ckatz53 and 7 others like this.
  4. Jan 26, 2020 at 8:27 AM
    Bonzen
    Installed and tested on Land Cruiser 200 as well.
    Rica25 likes this.
  5. Jan 26, 2020 at 8:46 AM
    Hobbesdsm
    Hobbesdsm New Member
    Eddie
    2016 crewmax limited
    TRD exhaust and rear sway bar, 2018 led headlights
    What’s wrong with oe mount?
  6. Jan 26, 2020 at 10:19 AM
    Bonzen
    The minute you take your truck off road and start using it, especially if you have a more capable aftermarket suspension system which allows you to push your truck past it's OEM designed limits, the engine mounts begin to fail. The soft weak rubber begins to over-flex, crack apart, and de-laminate. As this occurs, the entire weight of the engine begins to bounce in all directions, slamming up and down and basically beating the motor mount frame perches like a 600lb slide hammer. It's at this point your perches begin to crack apart and the frame begins to tear. After that, the exhaust rips, the aluminum transmission housing cracks apart, and the engine block itself can crack and rip the mounts right out of the block itself. Best case scenario you just have a torn rubber puck or a bent cast iron bracket and a lot of engine flex. But the hidden benefit is more power to the tires because your drivetrain isnt being twisted from motor torque. It stays put and that torque is sent to the ground.
  7. Jan 26, 2020 at 10:21 AM
    TheBeast The Beach
  8. Jan 26, 2020 at 10:27 AM
    Bonzen
    This customer had a bent bracket on one side and had to cut his mount apart to remove it due to rubber puck damage. His frame perches were also bent from the stock mount failing and the motor flex and excessive movement.
  9. Jan 26, 2020 at 10:32 AM
    Bonzen
    New engine mounts & installed. These work with long tube headers.
    Fits 2007 - up tundra & sequoia 5.7
    Also fits Landcruiser 200 and Lexus
  10. Jan 27, 2020 at 4:03 PM
    Tundra_power
    Tundra_power New Member
    Nick
    How much more vibration is it and how much power will you free up doing this mod.
  11. Jan 27, 2020 at 4:20 PM
    Whocares
    Whocares Member
    Whats the install process look like?
    AggiePhil, Rica25 and Bonzen[OP] like this.
  12. Jan 27, 2020 at 5:31 PM
    Sunnier
    Sunny
    San Diego, CA
    and @papasmurf beat the hell out of their trucks, and know how the OEM do not hold up to hard use.
  13. Jan 27, 2020 at 5:45 PM
    Vizsla
    Vizsla pretend2send
    13k miles and both my motor mounts are toast, so I’m giving these a try. But mine is from the frame slowly pushing in, resulting in frequent alignments, always going towards negative camber.:annoyed:
    C546DFF4-2AD8-4B17-894D-41653D598FCC.jpg 2C0E10EA-CBD8-4856-9799-D1FD0356E14E.jpg
  14. Jan 27, 2020 at 8:13 PM
    Bonzen
    I've sold about 500 sets of these types of motor mounts since the mid 2000s and only had one customer say he was bothered by the extra vibration. It's very minimal, really only noticable at idle, if noticed at all. But bigger off road tires, aftermarket suspension, big stereos, exhaust, lift kits, etc all add different driving characteristics and harmonics/sounds to the truck anyway. This is an upgrade that's designed to be cheap insurance to avoid thousands of dollars of possible damage when your stock oem motor mounts give up. Alot of bad things happen when your drivetrain starts banging around underneath your cab and inside your engine bay.
    As for exact horse power it would have to be dyno'd. But it's a noticable seat of the pants difference. It's simple physics though, energy that isnt lost thru the twisting and bouncing around of the drivetrain is now sent to the axles turning the tires.
    I'm being told it's a 2 hour average install time if you can do your own brakes. This is from 5 different sources. Floor jack, block of wood, basic harbor freight socket/wrenches.
    coldcanuk, nags, tundra_20 and 4 others like this.
  15. Jan 28, 2020 at 4:22 AM
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    Do you have a link to more info? I’m not instragram savvy. Is this mount all metal on metal or is there some sort of poly bushing in there that’s blending in with all the black? It looks like there might be a two-piece, ES control arm-style poly bushing there. Thanks.
  16. Jan 28, 2020 at 8:24 AM
    Tundra_power
    Nick
    Whats the price on these motor mounts
    Rica25 likes this.
  17. Jan 28, 2020 at 8:25 AM
    Tundra_power
    Nick
    I would buy them just for the increase in acceleration alone.
    nags, 15whtrd, Rica25 and 1 other person like this.
  18. Jan 28, 2020 at 5:21 PM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    2011 Silver Tundra SR5 4WD DC
    DAP Tune, Truxedo ProX15 bed cover, WildPeak AT3s
    It looks like the prices are in his signature area (area below posts)?
    Rica25 likes this.
  19. Jan 28, 2020 at 6:23 PM
    Tundra_power
    Nick
    You should definitely have a group buy.
    Rica25 likes this.
  20. Jan 28, 2020 at 8:53 PM
    Bonzen
    100% fabricated steel but yes with a polyurethane 1.75" bushing. This allows for a small amount of flex which is still required on a stock style truck frame.
    tundra_20, jc153, porkitt and 3 others like this.
  21. Jan 28, 2020 at 8:54 PM
    Bonzen
    $500 for the set.
    Rica25 likes this.
  22. Jan 28, 2020 at 8:55 PM
    Bonzen
    You'll notice it...I have customers telling me they can chirp tires in a higher gear when they couldn't before. These 5.7 motors flex alot. I had a customer take a go-pro under hood video and there is like inches of movement as the motor torques.
    Tundra Texan and tundra_20 like this.
  23. Jan 28, 2020 at 8:58 PM
    Bonzen
    Thinking about that....
    porkitt, nlaroy, Rica25 and 3 others like this.
  24. Jan 30, 2020 at 8:01 AM
    Bonzen
    A few nice tundras that are running my 4.7 and 5.7 motor mounts. Land Cruiser in Qatar too!
  25. Feb 2, 2020 at 6:59 AM
    Vizsla
    Vizsla pretend2send
    :anonymous: motor mount 1789BCCB-8B05-4117-9349-9071A59C71B8.jpg
    Terndrerrr, tundra_20, jc153 and 2 others like this.
  26. Feb 2, 2020 at 7:38 AM
    Bonzen
    That's some serious damage. The whole thru bolt/rubber section/metal housing just completely disintegrated :confused:
    Rica25 and Vizsla[QUOTED] like this.
  27. Feb 2, 2020 at 8:03 AM
    BIGUGLY
    Paul
    2018 Limited
    So would a daily driver, light tower and a truck that is used in hunting,farming loght off road and just plain general use have a need for this? Maybe not a total need but would the above warrant the expense.
    Planning on having the truck a long time.
  28. Feb 2, 2020 at 9:08 AM
    Bonzen
    I've sold a few sets to some customers that pretty much outlined exactly what you just wrote. Strictly tow vehicles and they wanted a little more power to the ground...but...they also ran a little bigger tire and like to hit some trails sometimes and might bounce the truck around a little more than normal. Is it likely in this scenario that your OEM mounts would fail...probably not. At least not quickly. I can tell you though that I've seen a underhood go-pro video of a 5.7 motor on the street and between shifts and acceleration that motor is literally all over the place. And that's on flat pavement.
  29. Feb 2, 2020 at 9:12 AM
    BIGUGLY
    Paul
    2018 Limited
    Thanks much. Group buy and probably can get by the Mrs.
    Tundyfundy and Bonzen[OP] like this.
  30. Feb 6, 2020 at 11:45 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    I'm gonna try and test fit these this weekend. My mounts looked like @Vizsla last year haha
    nlaroy, Rica25 and Bonzen[OP] like this.
